POV-Ray : Newsgroups : povray.beta-test : Known bugs 9 Mar 2002 Server Time
27 Apr 2026 19:14:40 EDT (-0400)
  Known bugs 9 Mar 2002 (Message 2 to 11 of 21)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Known bugs 9 Mar 2002
Date: 9 Mar 2002 15:48:54
Message: <3c8a7536$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3c8a4d2e@news.povray.org...
> * Radiosity bug (job000215)
>   (Rendering slows down when repeatedly started and stopped during radiosity
>   calculations.)
>   Reported in:
> Slow render time after several runs
> http://news.povray.org/3bd40c6d$1@news.povray.org
>   A possibly related report:
> radiosity problem
> http://news.povray.org/3c49968f@news.povray.org
This one     ||  ...
> * Radiosity sampling problems (job000177)
>   (radiosity sample counter is reset to the start every time, sampling
>   artefacts are produced)
>   Reported in:
> [bug]: radiosity sampling, with fix method.
> http://news.povray.org/3BC5A13E.9C022BD6@reading.ac.uk
> Radiosity samples during pretrace.
> http://news.povray.org/3c587c7a@news.povray.org
... and this one || refer to the same bug.
Jonathan.
Date: 10 Mar 2002 17:50:56
Message: <Xns91CDB5923AD94csbhccse@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3c8a4d2e@news.povray.org:
The list is missing the report I gave that shadowless lights don't
illuminate scattering media.
http://news.povray.org/povray.beta-test/22661/
Date: 10 Mar 2002 17:59:50
Message: <3c8be566@news.povray.org>
In article <3c8a4d2e@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> * Function redefinition bug
>   (Parser fails to trap some attempts to illegally redefined functions)
>   Reported in:
> can't redefine identifier
> http://news.povray.org/tis83ugh1kcc22h5o6is9qpkv61pjgunc0@4ax.com
> * POV-Ray crashes with some very long function definitions
>   (POV doesn't check when the max VM code is exceeded.)
>   Reported in:
> long function with crash
> http://news.povray.org/8pe56usuudisacgrocav0l0ovqvetsno83@4ax.com
> * Function namespace problem
>   (Declared function names can't be used as macro parameter names. Might
>   not be possible to be fixed with the current parser. This is being
>   investigated.)
>   Reported in:
> function declaration and namespace
> http://news.povray.org/l2ji3uc2k9su99o2gct3n2thgqoq7f4pd5@4ax.com
> * Functions in arrays problem
>   (Using the function at the index 0 of an array causes an error/crash.)
>   Reported in:
> Still a first function initialisation error?
> http://news.povray.org/3C612786.9000004@reading.ac.uk
All these will be fixed in the next beta (at least I hope they will as I can't
reproduce all of them).
    Thorsten
Date: 10 Mar 2002 18:20:39
Message: <3c8bea47@news.povray.org>
>   calculations.)
>   Reported in:
> radiosity problem
<snip>
Can anybody confirm any of these three are still in the current beta?
    Thorsten
e-mail: tho### [at] trfde
Date: 10 Mar 2002 18:53:05
Message: <3c8bf1e1@news.povray.org>
> >   calculations.)
> >   Reported in:
> > radiosity problem
> <snip>
The last two ones seem to have gone.
Jonathan.
Date: 11 Mar 2002 07:19:48
Message: <618p8u0ak1qqsna87v1dhhkm2tc9c1o91o@4ax.com>
On 9 Mar 2002 12:58:07 -0500, Warp <war### [at] tagpovrayorg> wrote:
>  Officially confirmed bugs:
>  Bugs with no official confirmation:
>  Problems still being worked on:
>  Fixed in next beta:
I can't find my last week report in any category. What is the current status
of http://news.povray.org/uoj68uk5m391emvphovqfbg5vl0en7h2q6%404ax.com ?
ABX
Date: 11 Mar 2002 07:53:28
Message: <3c8ca8c8$1@news.povray.org>
That it will be added to the next posting of the list :-)
The category it will be in (officially confirmed / not confirmed) depends on
your ability to provide a shorter example.
    Thorsten
Date: 11 Mar 2002 07:56:08
Message: <3c8ca968@news.povray.org>
  I think it was pretty unclear whether it is a bug or just a design
decision.
  If you can convince me that it's a bug, I can add it.
Date: 11 Mar 2002 07:59:34
Message: <3c8caa35@news.povray.org>
  Is only the problem described in them gone, or the actual bug they are
referenced in?
  If it's the former case, then those reports were not related to the bugs
in question and thus I should remove them from there.
Date: 11 Mar 2002 08:06:13
Message: <3c8cabc5@news.povray.org>
  This just looked so similar to
  Reported in:
that I wasn't sure at all if it was a different problem.
  Any ideas?
