POV-Ray : Newsgroups : povray.beta-test : [Windows] Modal dialog boxes again Server Time
31 Mar 2026 02:49:08 EDT (-0400)
  [Windows] Modal dialog boxes again (Message 1 to 6 of 6)
Subject: [Windows] Modal dialog boxes again
Date: 2 Mar 2002 14:18:15
Message: <3c812577$1@news.povray.org>
(POV-Ray 3.5 beta 11 on Windows 98)
Yesterday I must have closed POV-Ray when it was minimized, and today when I
started it up, I could not restore it. When I left-clicked on the taskbar
button, the button depressed but nothing happened. When I right-clicked on
the taskbar button, I didn't get a context menu. I tried to close it with
Ctrl+Alt+Del, and it said "This program is not responding". I closed it
anyway, and started it up again. The same thing happened.
Then I remembered the strange things that used to happen with modal dialog
boxes being displayed when the window was minimized. I started POV-Ray
again, clicked on the taskbar button, and pressed Enter to try to close
whatever dialog box was displayed. It worked, and I was then able to restore
the window.
I have a feeling the problem this time is the new about box, which I've
occasionally seen displayed on startup in the recent betas. If POV-Ray
starts up minimized (which I still think it should never do, but anyway), it
needs to make sure that no modal dialog boxes are displayed.
Anders
light_source{6#local D#macro B(E)#macro A(D)#declare#declare C=mod(E
D);E=(E-C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(C<3)
}cylinder{0(C=<1 2>).2translate<D+C*A(2)A(4)#else}intersection{torus
{1 .2}box{-2y}rotate<1 0C>*90translate<D+1A(2)*2+1#end-2 13>pigment{
rgb x}finish{specular 1}#end#end#end=-8;1B(445000298)B(519053970)B(
483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Subject: Re: [Windows] Modal dialog boxes again
Date: 2 Mar 2002 14:24:31
Message: <3c8126ef$1@news.povray.org>
BTW, I just made a simple test application that displays a modal dialog box
while it's minimized. The dialog box was actually displayed on the screen,
and I could close it and then restore the application. Why doesn't it work
this way in POV-Ray?
Anders
Date: 3 Mar 2002 06:07:52
Message: <3c820408$1@news.povray.org>
Something similar happens sometimes on my windows system (Win98SE) with
other applications. They are minimized, but I have to use the context menu
to maximize them. When it isn't possible to use the context menu (due to a
modal dialog), this lets the application perhaps crash. So I think it's a
problem of windows and not a problem of POV-Ray.
Felix Wiemann
Date: 4 Mar 2002 20:32:13
Message: <3c84201d@news.povray.org>
In future (beta 13 or later) POV-Ray will not minimize itself when restarted,
even if it was minimized when it exited.
-- Chris
Date: 5 Mar 2002 06:38:59
Message: <slrna89bg0.k7i.steve@zero-pps.localdomain>
POV beta 12 on Windows 95 Compaq PII 266 with 64M RAM.
Exact as reported above, but for me this happened on install, at the end of
the install I say yes to a sample render, then minimised the windows and
proceded to do some other work, the sound played when the render finished,
and a message box appeared so I clicked on it and continued with what I was
working on.
Later on I noticed that there was a POV icon on the task bar it wouldn't
open, no context menu so I tried to end the task, and when I rebooted
the icon was in the taskbar again and also wouldn't respond.
A reinstall fixed this, so I tested it a third time by installing and
minimising the windows at the end of tthe process, and the same thing
happened again.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 7 Mar 2002 10:33:29
Message: <3c878849@news.povray.org>
I too can confirm. I'm glad I read this message again, because I really had
no idea how I could get to use POV-Ray when it kept doing like that!
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
