|  |  | This code works in POVRay 3.1
3.5 complains about not being able to open the font file (wingdings.ttf) -
Other standard fonts seem to work. Most of my downloaded TTF files don't
work either, but that's ok - as long as the official Microsoft ttf's work...
can anyone confirm?
I don't use any other include files than colors.inc - so you can test this
code on 3.1 and 3.5.
sky_sphere{
      agate
      color_map{
        [0.0      color Blue]
        [0.5     color Gray75]
        [1        color White]
      scale .35
  location <-.5, 1, -2.5>
  //location <1.2, .7, -3 >
  look_at <1.2, .7, 0>
#declare Green_Frame =
merge {
  difference{
        box {
          <0, 0, 0>
          <1, 1, 1>
          scale <2.2, .8, .1>
        box {
          <0, 0, 0>
          <1, 1, 1>
          scale <2, .6, .2>
          translate <.1, .1, -.05>
   box {
     <0, 0, 0>
     <1, 1, 1>
     scale <.1, .6, .2>
     translate <.9, .1, 0>
   text {ttf "arial.ttf" "Go" 1, 0
     pigment { color White }
     finish {specular .25}
     scale .5
     translate <.2, .2, 0>
   text {ttf "arial.ttf" "Mail" 1, 0
     pigment {color Black}
     scale .5
     translate <1.05, .2, 0>
#declare Granite_Block =
box {
  <0,0,0>
  <1,1,1>
  scale <2.4, 1.5, 2.5>
#declare Envelope =
  text {ttf "WingDings.ttf" "*" 1, 0
    scale .4
#declare Domain =
  text { ttf "arial.ttf" ".co.za" 1 ,0
   scale .5
object { Granite_Block
      granite
      color_map {
        [0.0    color rgb <.1, .1, .45>]
        [0.1   color rgb <.3, .1, .6>]
        [0.3   color rgb <.1, .3, .45>]
        [1      color rgb <.3, .1, .5>]
      scale .8
object { Green_Frame
      bozo
      color_map {
        [0.0    color rgb <.3,.6,.3>]
        [0.33   color rgb <.3,.3,.3>]
        [0.66   color rgb <.1, .75, .1>]
        [1      color rgb <.3, .5, .3>]
      turbulence 2
      scale .2
   scale z*.5
   translate <.1, .6, -.05>
object { Envelope
  texture{
  rotate z*30
  translate <.25, .08 ,-.05>
object { Domain
    pigment {color Black }
  translate <.8, .2, -.05>
plane {
  <0, 1, 0>, 0
    color Blue
  normal {
   ripples
   scale .4
   translate <2, 1, 0>
  finish {
    reflection .7
    specular .15
height_field {
    tga "basic.tga"
    smooth
      agate
      color_map {
        [0.0   color Brown]
        [0.5   color .3*Green]
        [0.9   color Yellow]
      scale .8
    scale <20, 1, 20>
    translate <-10, -.05, -5>
fog {
  fog_type 2
  distance 5
  fog_offset .2
  fog_alt .6
  color White
  turbulence .5
light_source {
  <1.5, 1.5, -3>
  color White
