POV-Ray : Newsgroups : povray.beta-test : TTF Files Server Time
18 Feb 2026 04:50:03 EST (-0500)
  TTF Files (Message 1 to 6 of 6)
Subject: TTF Files
Date: 21 Feb 2002 06:57:46
Message: <3c74e0ba@news.povray.org>
This code works in POVRay 3.1
3.5 complains about not being able to open the font file (wingdings.ttf) -
Other standard fonts seem to work. Most of my downloaded TTF files don't
work either, but that's ok - as long as the official Microsoft ttf's work...
can anyone confirm?
I don't use any other include files than colors.inc - so you can test this
code on 3.1 and 3.5.
sky_sphere{
      agate
      color_map{
        [0.0      color Blue]
        [0.5     color Gray75]
        [1        color White]
      scale .35
  location <-.5, 1, -2.5>
  //location <1.2, .7, -3 >
  look_at <1.2, .7, 0>
#declare Green_Frame =
merge {
  difference{
        box {
          <0, 0, 0>
          <1, 1, 1>
          scale <2.2, .8, .1>
        box {
          <0, 0, 0>
          <1, 1, 1>
          scale <2, .6, .2>
          translate <.1, .1, -.05>
   box {
     <0, 0, 0>
     <1, 1, 1>
     scale <.1, .6, .2>
     translate <.9, .1, 0>
   text {ttf "arial.ttf" "Go" 1, 0
     pigment { color White }
     finish {specular .25}
     scale .5
     translate <.2, .2, 0>
   text {ttf "arial.ttf" "Mail" 1, 0
     pigment {color Black}
     scale .5
     translate <1.05, .2, 0>
#declare Granite_Block =
box {
  <0,0,0>
  <1,1,1>
  scale <2.4, 1.5, 2.5>
#declare Envelope =
  text {ttf "WingDings.ttf" "*" 1, 0
    scale .4
#declare Domain =
  text { ttf "arial.ttf" ".co.za" 1 ,0
   scale .5
object { Granite_Block
      granite
      color_map {
        [0.0    color rgb <.1, .1, .45>]
        [0.1   color rgb <.3, .1, .6>]
        [0.3   color rgb <.1, .3, .45>]
        [1      color rgb <.3, .1, .5>]
      scale .8
object { Green_Frame
      bozo
      color_map {
        [0.0    color rgb <.3,.6,.3>]
        [0.33   color rgb <.3,.3,.3>]
        [0.66   color rgb <.1, .75, .1>]
        [1      color rgb <.3, .5, .3>]
      turbulence 2
      scale .2
   scale z*.5
   translate <.1, .6, -.05>
object { Envelope
  texture{
  rotate z*30
  translate <.25, .08 ,-.05>
object { Domain
    pigment {color Black }
  translate <.8, .2, -.05>
plane {
  <0, 1, 0>, 0
    color Blue
  normal {
   ripples
   scale .4
   translate <2, 1, 0>
  finish {
    reflection .7
    specular .15
height_field {
    tga "basic.tga"
    smooth
      agate
      color_map {
        [0.0   color Brown]
        [0.5   color .3*Green]
        [0.9   color Yellow]
      scale .8
    scale <20, 1, 20>
    translate <-10, -.05, -5>
fog {
  fog_type 2
  distance 5
  fog_offset .2
  fog_alt .6
  color White
  turbulence .5
light_source {
  <1.5, 1.5, -3>
  color White
Subject: Re: TTF Files
Date: 21 Feb 2002 07:07:05
Message: <lgo97ussdmpiotl7ik7cgavu9f6md121pk@4ax.com>
On Thu, 21 Feb 2002 13:56:31 +0200, "Soulstorm" <der### [at] gomailcoza>
Are you sure you wrote font name properly ?
There are two standard microsoft fonts
"Webdings.ttf" and "wingding.ttf".
btw: when you post some source to show problem try to make it as short as
possible
ABX
Date: 21 Feb 2002 07:08:55
Message: <3C74E357.340D5509@gmx.de>
> can anyone confirm?
That does not make much sense, your problem is obviously related to the
ttf files, i presume they are not accessible in Library_Path, check the
docs (section 6.5.1.13) concerning this.  Library_Path settings probably
differ in your 3.1 and 3.5 configuration. If you are working on Linux note
that file names are case sensitive.
Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 21 Feb 2002 08:01:30
Message: <3c74efaa@news.povray.org>
Yeah, sorry 'bout the long code...it's just the scene i was working on
as-is.
I was about to start with a story about me not being stupid and knowing the
difference between webdings and wingdings - but alas WingDing is right!
Thanks.
-ss-
Date: 24 Feb 2002 06:26:35
Message: <Xns91BF4186DBF30mrartchesapeakenet@204.213.191.226>
Christoph Hormann scribis news:3C74E357.340D5509@gmx.de:
Problem -is- related to ttf files, but not the Library_Path settings.
I can't use this font even if I explectly define the file location.
Gis poste, Arto.
Date: 26 Feb 2002 21:08:11
Message: <3c7c3f8b$1@news.povray.org>
I remember my friends laughing at me because I discovered that my internet
connection didn't work because I forgot to turn on my modem. hahahahahah.
