POV-Ray : Newsgroups : povray.beta-test : has any one got the new version to work Server Time
30 Sep 2024 15:22:30 EDT (-0400)
  has any one got the new version to work (Message 1 to 8 of 8)
Subject: has any one got the new version to work
Date: 14 Feb 2002 14:42:56
Message: <3c6c1340@news.povray.org>
I have down loaded it 4 time now, it looks 7.5Mb long (not the 7.9Mb it said
on the web site)
and it will not install.
Roger
Subject: Re: has any one got the new version to work
Date: 14 Feb 2002 14:50:24
Message: <3c6c1500@news.povray.org>
Obviously we all got it to work, what do you think all of the messages in
this newsgroup are about?
"Roger" <r.o### [at] btopenworldcom> wrote in message
news:3c6c1340@news.povray.org...
said
> on the web site)
> Roger
Date: 14 Feb 2002 16:24:24
Message: <1103_1013721819@selliot>
> said
> > on the web site)
> > Roger
Are you using a download agent or just IE. I refuse to rely in the built in downloader
in IE, since it can consistantly screw up (such as always failing at 7.5M of a 7.9M
file).
Apparently MS doesn't consider this important enough to fix. :p
Date: 14 Feb 2002 18:39:27
Message: <3c6c4aaf@news.povray.org>
7.53 megabytes downloaded (with IE).  Installed just fine.  Works just fine.
Win NTv4SP5 PII(400MHz)
Jim
said
> on the web site)
> Roger
Date: 14 Feb 2002 19:01:11
Message: <3c6c4fc7@news.povray.org>
said
> on the web site)
It's 7,899,734 bytes, or 7.53 MB. (Yeah, yeah, I know about the recent
"standard" defining 1 MB = 1,000,000 bytes ... what do they know?)
If you know how to compute MD5 sums:
f559ef97cf34e9662f319863077fe668 *povwin35-beta-11.exe
Anders
light_source{6#local D#macro B(E)#macro A(D)#declare#declare C=mod(E
D);E=(E-C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(C<3)
}cylinder{0(C=<1 2>).2translate<D+C*A(2)A(4)#else}intersection{torus
{1 .2}box{-2y}rotate<1 0C>*90translate<D+1A(2)*2+1#end-2 13>pigment{
rgb x}finish{specular 1}#end#end#end=-8;1B(445000298)B(519053970)B(
483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Date: 15 Feb 2002 02:58:00
Message: <qofp6u47c44a9eect6f17f7q6568n872lc@4ax.com>
On Thu, 14 Feb 2002 19:42:31 -0000, "Roger" <r.o### [at] btopenworldcom> wrote:
> on the web site)
I would want to give you an advice to download it via ftp. But somehow it's
not available there.
ABX
Date: 15 Feb 2002 14:26:51
Message: <d4oq6u0hf5td5k85f2nvm234qrar8gj27a@4ax.com>
>on the web site)
  Roger, I can try to e-mail it to you if your ISP can accept an attachment
of this size. Keep trying to figure out what is going wrong at your end,
though, because the binary at povray.org is good (that's where I got it
from).
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
Date: 15 Feb 2002 14:51:02
Message: <3c6d66a6@news.povray.org>
I am using a win xp pro on a P4, I will give it an other try.
"Jim Kress" <dea### [at] kressworkscom> wrote in message
news:3c6c4aaf@news.povray.org...
fine.
> Jim
> said
> > on the web site)
> > Roger
