I just tried rendering the sample scene using POV 3.5 beta 11:
In scenes\advanced\blocks\stackertransp.pov
with the following changes:
Comment out the following line the first time you run, to generate a 1200
block data file. If you run again, you can uncomment it back, not to have to
generate the data file:
// #declare WriteFile=false; // turns off the generation of the file, just
read them from the previous file
Modify the following line:
#declare num=1200;
Modify the global_settings as follows:
global_settings{
radiosity{
pretrace_end 0.01
count 400
recursion_limit 1
nearest_count 9
gray_threshold 0
error_bound 0.01
max_trace_level 50
adc_bailout 0.01
Now, render the file at 1024x768 with no AA, preferably on a relatively fast
machine. pvengine.exe will leak RAM the entire time and in about 8 hours of
rendering on a >=1GHz PIII machine, your virtual memory will be down a good
600MB. Note this leaked memory will be lost, until you restart the app. Note
that the radiosity pre-processing will take some time, and memory will
accumulate normally, I would hope, during this perioud. The fun leak part is
during the actual render.
IMPORTANT NOTE TO MEMORY LEAK HUNTERS
For people using Task Manager on Windows NT/2000/XP to diagnose memory
leaks, you should not be looking at the Mem Usage column. This represents
the process' working set, which the OS can trim, not the actual virtual
memory utilization. To see how much total virtual memory your process is
utilizing in task manager, do the following:
- Go to View/Select Columns...
- Check Virtual Memory Size
Now you will see a VM Size column. This represents the amount of virtual
memory your process is currently using. If this amount grows and doesn't get
reclaimed, a memory leak is usually indicated.
Mike
Subject: Re: Memory leak with sample scene in beta 11
Date: 14 Feb 2002 14:26:10
Message: <3c6c0f52$1@news.povray.org>
As a follow up, I believe that the memory leak could be related to the
radiosity settings.
"Michael Goldshteyn" <mik### [at] wwa com> wrote in message
news:3c6bc4dc$1@news.povray.org...
to
> #declare num=1200;
> global_settings{
> radiosity{
> pretrace_end 0.01
> count 400
> recursion_limit 1
> nearest_count 9
> gray_threshold 0
> error_bound 0.01
> max_trace_level 50
> adc_bailout 0.01
fast
of
good
Note
is
get
> Mike
news:3c6c0f52$1@news.povray.org...
> radiosity settings.
Having tried your example out to 25% of a render I can say that I did see a
page file growing as it progressed. Beyond that I have no idea what would
cause it to increase over time because I never checked before during a
render, only the stats afterward or between animation frames.
Since you suspect it to be radiosity causing it I guess you meant there
might be a final stage while the rendering proceeds and yet isn't making
more sampling passes. I don't want to conjecture anything though without
knowing if there is continued radiosity sampling during the final phase of
render.
Yeah... I'm just here for moral support.
bob h
Date: 15 Feb 2002 09:03:18
Message: <3c6d1526@news.povray.org>
Not sure whether there is or isn't, but without the radiosity, the
pvengine.exe process stays constant at around 83.5 MB. With radiosity, it
grows and grows until it hits around 650MB 75% into the trace. Something is
surely awry.
"bob h" <omn### [at] charter net> wrote in message
news:3c6c48a4@news.povray.org...
> > radiosity settings.
a
> render.
> bob h
Date: 15 Feb 2002 10:21:56
Message: <3c6d2794@news.povray.org>
> With radiosity, it
Note: radiosity takes samples while rendering, that is why the radiosity
data is stored when interrupting renders!
thorsten
