POV-Ray : Newsgroups : povray.beta-test : Code-Max issue Server Time
11 Apr 2026 01:54:59 EDT (-0400)
  Code-Max issue (Message 1 to 7 of 7)
Subject: Code-Max issue
Date: 12 Feb 2002 17:36:58
Message: <3c69990a@news.povray.org>
Hi...
I just downloaded the beta, and there are two things I don't quite like
about the editor.
#1:  Say I have a line that is the following:  "    //test".  I put the
cursor before the // and press Shift+<Left Arrow>.  It selects the white
space up to the second space, and not all the way back to the first space.
Ctrl+Backspace does the same thing, where it deletes up to the second space,
but not the first.
#2:  When I close off a block with the curly brackets, I have to backspace
in order to have the end curly bracket line up with the block's initial open
curly bracket.  Although this is not really a performance issue, it is a
little annoying.
For example:
    sphere {
        <0, 0, 0>, 1
where I would like it to automatically match the "}" to the indentation of
the "sphere" line.
Thanks,
Cliff Hewitt
Subject: Re: Code-Max issue
Date: 12 Feb 2002 17:55:43
Message: <3c699d6f$1@news.povray.org>
Please read <http://news.povray.org/povray.beta-test/17912/116102/>
Date: 13 Feb 2002 03:11:22
Message: <jm7k6u4bgie1u9vum34n2qoj46kjknbin5@4ax.com>
On Tue, 12 Feb 2002 17:31:29 -0500, "Cliff Hewitt" <som### [at] attnet> wrote:
> about the editor.
It's not a place to write what you don't like. It's place for bug reports.
Your wishes belongs to povray.windows or povray.general group rather.
ABX
Date: 13 Feb 2002 10:12:29
Message: <3c6a825d@news.povray.org>
Right, sorry:
POV beta 11, Windows 2000, on a Pentium III 933, 512 MB RAM.
It also happens in the VC version, but alas, not in POV 3.1.
Also, I apologize if this has been brought up before, and understand that
this isn't a critical issue (but yes, #1 is what I consider to be a bug).
Thanks again for your time,
Cliff Hewitt
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c699d6f$1@news.povray.org...
Date: 13 Feb 2002 14:23:39
Message: <3c6abd3b$1@news.povray.org>
open
> little annoying.
BTW:
Under editor preferences: Language/Tabs tab, set "auto-indentation" to
"follow language scoping"
when you hit return after a curly bracket it will do what you are asking
So this is neither a problem nor a bug.
-tgq
Date: 13 Feb 2002 15:42:14
Message: <3c6acfa6@news.povray.org>
I also thought that that was what it was, but no, it doesn't align them as
such.  Well, no big deal, I suppose.  I know there are better things for the
POV Team to do than this.  :^)
Thanks,
Cliff Hewitt
"TinCanMan" <Tin### [at] hotmailcom> wrote in message
news:3c6abd3b$1@news.povray.org...
> BTW:
> -tgq
Date: 13 Feb 2002 16:09:48
Message: <3c6ad61c@news.povray.org>
Oh, sorry -- I just tried it again.  I was unaware that I needed to press
<Enter> for the change to take effect.  Thanks for the help.
Cliff Hewitt
