|  |  | Hi!
Is it just me, or is that Crash with to many Photons not in the list?
It was reported and confirmed in this thread
http://news.povray.org/3bb5d946$1@news.povray.org. The given demo scene
still crashes if you use "count 130000".
And there was another report of a crash with photons under Linux in
http://news.povray.org/3C4D93F1.2000005@gmx.de
Maybe they are the same, maybe not. Both were confirmed afaiks.
Greetings,
Marc-Hendrik
|  |  | Wasn't it Marc-Hendrik Bremer who wrote:
>Hi!
Yes. I missed that.
That one is in the list.
They sound the same to me, and the one that doesn't say it was Linux-
specific doesn't crash on my Windows system. The one that does say it's
Linux-specific is in some weird BZ2 format that my machine has never
heard of, so I can't tell how similar the code is.
I'll stick them next to each other in the list.
Mike Williams
Gentleman of Leisure
|  |  | Mike Williams schrieb in Nachricht ...
That one now only crashes if you use "count 130000" in the photons-block. It
does not crash on my machine either if you use "spacing".
Marc-Hendrik
That would be bzip2.  It shouldn't be too hard to find an implementation
for Windoze.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
|  |  | Ron Parker <ron### [at] povray org> wrote:
: That would be bzip2.
  Which is a great compression tool.
  For example, I tried compressing all the html files of the povray
documentation (about 3 MB) to a zip-file (maximum compression, of course) and
to a bz2-file (maximum compression):
docs.html.bz2:  419 803 bytes.
docs.zip:       559 430 bytes.
-1<.7438.1795>1,20)M(1<.77595.13699>30,20)M(3<.75923.07145>80,99)// - Warp - Post a reply to this message
