|  |  | Intel b10 compile on Win95B
Open the ini dlg, press clear, exit POVWin, restart POVWin & bring up the
ini dlg
This causes a unhandled stack overflow exception according to MSVC++,
usually in Kernel32.dll
This occurs when the secondary ini path (SecondaryINIFile in pvengine.ini)
ends in a directory
 (eg %POV%\renderer\ or %POV%\Insert Menu\ ) under and including the pov
install dir, but not always
Bye,
Pabs
|  |  | "Pabs" <pab### [at] NOzSiPpA Mto> wrote in message
news:3c57985c$1@news.povray.org...
> ini dlg
> ends in a directory
Interesting, yes indeed it does crash POV-Ray for me too... under WinXP it
simply closes without a trace (no pun intended).
What's worse is that I can't get back into the INI dialog again now (darn
you ;-)) and Tools menu then Edit Resolution INI also fails claiming unable
to locate a .txt file.
bob h Post a reply to this message
|  |  | For anyone testing that out yourselves, to get back to normal again:
Edit the POV-Ray\ini\pvengine.ini file and add quickres.ini to the end of
the line under [General] which says SecondaryINIFile=
Sorry - I should have told u about that.
