POV-Ray : Newsgroups : povray.beta-test : [win] ini dlg crash - stack overflow Server Time
14 Dec 2025 17:01:17 EST (-0500)
  [win] ini dlg crash - stack overflow (Message 1 to 4 of 4)
Subject: [win] ini dlg crash - stack overflow
Date: 30 Jan 2002 01:53:16
Message: <3c57985c$1@news.povray.org>
Intel b10 compile on Win95B
Open the ini dlg, press clear, exit POVWin, restart POVWin & bring up the
ini dlg
This causes a unhandled stack overflow exception according to MSVC++,
usually in Kernel32.dll
This occurs when the secondary ini path (SecondaryINIFile in pvengine.ini)
ends in a directory
 (eg %POV%\renderer\ or %POV%\Insert Menu\ ) under and including the pov
install dir, but not always
Bye,
Pabs
Subject: Re: [win] ini dlg crash - stack overflow
Date: 30 Jan 2002 11:49:53
Message: <3c582431@news.povray.org>
"Pabs" <pab### [at] NOzSiPpAMto> wrote in message
news:3c57985c$1@news.povray.org...
> ini dlg
> ends in a directory
Interesting, yes indeed it does crash POV-Ray for me too... under WinXP it
simply closes without a trace (no pun intended).
What's worse is that I can't get back into the INI dialog again now (darn
you ;-)) and Tools menu then Edit Resolution INI also fails claiming unable
to locate a .txt file.
bob h
Subject: Re: [win] ini dlg crash (fixing it back)
Date: 30 Jan 2002 11:55:29
Message: <3c582581@news.povray.org>
For anyone testing that out yourselves, to get back to normal again:
Edit the POV-Ray\ini\pvengine.ini file and add quickres.ini to the end of
the line under [General] which says SecondaryINIFile=
Date: 31 Jan 2002 02:40:53
Message: <3c58f505@news.povray.org>
Sorry - I should have told u about that.
