POV-Ray : Newsgroups : povray.beta-test : Initialisation of a 4-vector array Server Time
2 Nov 2024 05:20:02 EDT (-0400)
  Initialisation of a 4-vector array (Message 1 to 4 of 4)
Subject: Initialisation of a 4-vector array
Date: 24 Jan 2002 05:55:55
Message: <3c4fe83b@news.povray.org>
pov 3.5 b 10
win
With the following, w4[0].t is not set correctly.
w4[1].t and w4[2].t are set correctly.
Curiously, this does not happen with an array of only 2 elements.
  #local a = array[3] {0.123, 0.456, 0.789}
  #local w = array[3] {x, y, z}
  #local w4 = array[3]
  #local ix = 0;
  #while (ix<3)
    #declare w4[ix] = a[ix]*t + w[ix];
    #debug concat(str(a[ix], 6, 3), " ", str(w4[ix].t,6,3),"\n")
    #local ix=ix+1;
Subject: Re: Initialisation of a 4-vector array
Date: 24 Jan 2002 06:09:56
Message: <nbqv4u431tn4ve7pa3ca2dndn8qd0hfbq1@4ax.com>
On Thu, 24 Jan 2002 11:58:13 +0100, "mm" <mmo### [at] wanadoofr> wrote:
> pov 3.5 b 10
> win
please read point 2 and 3 of 1.11.8 in documentation
your example outputs two columns with content of a[] on my machine
so I can't confirm described behaviour but ...
... when I replace above with
#declare w4[ix] = (a[ix]*t) + w[ix];
then first number in second column is strange: sometimes proper, sometimes
veeery long, and sometimes "-1.#QO".
POV 3.5 b 10.icl on PII 233 128 MB with NT 4 Sp 6
ABX
Date: 24 Jan 2002 06:18:12
Message: <3c4fed74$1@news.povray.org>
Confirmed.
Confirmed.
It seems to be a problem with adding 4D and 3D-vectors. With 4D-vectors
used in array w, it doesn't occur. When using {x + 0, y + 0, z + 0}
instead of {x, y, z}, the numbers are:
0.123 -1.#QO
0.456  0.456
0.789  0.789
When rendering with str(w4[ix].x,6,3) and then rendering with
str(w4[ix].t,6,3), it's one time correctly calculated. The error comes
back when rendering the same scene again.
Date: 24 Jan 2002 06:23:14
Message: <3c4feea2@news.povray.org>
> Confirmed.
I forgot to say that the number I get is very long.
Intel P3 600 Mhz, Win 98 SE, 128 MB, POV-Ray WinBeta 10
