POV-Ray : Newsgroups : povray.beta-test : Heightfield bug (most probably an inverted normals problem) Server Time
8 Apr 2026 02:12:22 EDT (-0400)
  Heightfield bug (most probably an inverted normals problem) (Message 21 to 27 of 27)
Subject: Re: More info
Date: 24 Jan 2002 07:51:51
Message: <3c500367@news.povray.org>
: I can be completly offtopic but could be normal determined by order of vertices
: in triangle?
  I didn't understand this.
  The problem is not determining the normal. The problem is just that if
the angle between the incoming ray and the normal vector returned by the
object have an angle <90 degrees, the normal is inverted.
  This works just fine in most cases (and it has to be done this way). The
only problem happens with smooth triangles and smooth heightfields in certain
cases.
  As for lighting, this problem goes away by making the object
double-illuminated (because then it doesn't matter which way the normal
is pointing). However, as for the slope pattern, the solution is not so simple
(double_illuminate is used only for lighting and can't be used for slope
pattern calculation).
  By the way: In a heightfield the problem with the slope y pattern goes
away if you "mirror" the color_map around 0.5 (of course it doesn't work if
the slope is anything else than y), besides making the heightfield
double-illuminated.
  With smooth meshes which use the slope pattern there's no currently fix,
AFAIK.
Date: 24 Jan 2002 08:01:05
Message: <n9105ugce60m3aa6lgn68e98knkimmrvjc@4ax.com>
I see, sorry then.
ABX
Subject: Re: More info (Was: Heightfield bug (most probably an inverted normals problem))
Date: 24 Jan 2002 09:48:07
Message: <3C501EB7.263F96C0@atosorigin.com>
> in triangle?
From memory:
In 3.1 code, the short answer is NO, at least for mesh,
because the mesh code is free to reorder the vertices of any single triangle.(*)
So even if you carefully generate all your triangles with a +side and -side,
once in the mesh structure it might be impossible to get back to the original
order. It's often simpler to use a smooth_triangle which allow to explicitely
specify a normal for each vertex (but take more memory, of course).
(*) and it does it, according to its own private criteria.
Non Sine Numine
http://grimbert.cjb.net/
Date: 24 Jan 2002 16:06:48
Message: <4uc05u05ad0l8ocf0mcm1vb0v1lokui2lq@4ax.com>
<abx### [at] babilonorg> wrote:
>not exactly
>I proposed this becouse I always generate meshes from triangles builded in one
>direction (ok, almost always).
Yes, but that's you. You're not the average Joe User.
>But renderer can't decide as I understand.
Yet :)
Peter Popov ICQ : 15002700
Date: 24 Jan 2002 23:33:20
Message: <chrishuff-6DA92A.23343824012002@netplex.aussie.org>
In article <9uuv4uoaebc3dldemv9snhjmopultmctlj@4ax.com>,
 Peter Popov <pet### [at] vipbg> wrote:
> Then the renderer would have to trust that the order is correct, and
> that is the task of either the export utility or the scene that
> generates it. In any case the user shouldn't be doing the renderer's
> job.
No. There is no way for the renderer to reliably determine the correct
normal, and such a mechanism would break many meshes that use the
winding to determine it. It normally isn't a problem anyway, since POV
renders both sides of the triangle.
And it isn't related to the height field problem, which has more to do
with the interpolation of smooth triangle normals.
Date: 24 Jan 2002 23:36:29
Message: <chrishuff-B76379.23374724012002@netplex.aussie.org>
In article <3C501EB7.263F96C0@atosorigin.com>,
> triangle.(*)
Not true. The mesh stores the vertex *vectors* separately, the triangles
then refer to that list. The triangles still know what order the
vertices are in.
Proof? Use interior_texture on a mesh. The height-field macros make good
examples...
Date: 6 Feb 2002 07:18:40
Message: <3c611f20@news.povray.org>
> macros make good examples...
And after I fixed the height-field macros you even get the interior texture
on the *inside*, contrary to how it was before... ;)
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
