Subject: Re: More info (Was: Heightfield bug (most probably an inverted normals problem))
Date: 22 Jan 2002 14:24:14
Message: <3C4DBC5C.BA61316@gmx.de>
Warp wrote:
> It's not actually a heightfield bug. It's a more general phenomenon. If the
> angle between the normal vector returned by the object (any object) and the
> incoming ray is <90 degrees, then the normal vector is inverted.
I think it would be interesting to know how other raytracers handle this.
Christoph Hormann <chr### [at] gmx de>
Date: 23 Jan 2002 08:15:11
Message: <3c4eb75f@news.povray.org>
the
the
Imho these bugs can only appear if the normal is somehow modified.
Wouldn't it be possible to just test the unmodified normal?
#local T=text{ttf"timrom.ttf""Simon Adameit".01,0}#local Y=1;#while(Y>-1)
#local X=0;#while(X<7)#local O=trace(T<X,Y><X,Y>+z);cylinder{<X-3,Y,5>*.01
<X-3,Y,5>*.01+5e-3,5e-5pigment{rgb 25*O}}#debug chr(83-(O.x=0)*51)#local
X=X+.05;#end#debug"\n"#local Y=Y-.05;#end
Subject: A possible solution, though difficult (Was: More info)
Date: 23 Jan 2002 08:57:59
Message: <3c4ec167@news.povray.org>
Looking at the code and testing a bit it's now extremely clear why this
artifact happens. It's not a bug, it's just a side-effect of normal
perturbation in smooth triangles.
One possible solution is to invert the normal if the angle between the
incoming ray and the unmodified triangle normal is <90 and the angle between
the modified normal and the incoming ray is >90, or the other way around.
That is, for example in the heighfield function which returns the normal
vector for a certain point, in the block where it is calculated for a smooth
heightfield, something like this is done:
if(dotProduct(incomingRay,unmodifiedNormal)*dotProduct(incomingRay,Result)<0)
invert(Result);
The effect of this is that when the problematic case happens, the normal
is inverted inside the heightfield code. Then it's inverted again at the upper
level, thus nullifying the inversion.
However, there's one big problem here: As far as I can see, the normal
calculation function has no access to the incoming ray.
Any ideas?
> Any ideas?
Two...:
-(bad) Put the incoming ray in a global... not on the head, not on the head
- Add a ray parameter to all the involved functions going from the function
where it is needed upto the function it is already available.
But you might end up with having to update all the objects (at least,
the prototype of the functions). And stack size is not infinite...
(ok, it can be just a pointer to the ray structure, that's not that big).
Non Sine Numine
http://grimbert.cjb.net/
In article <3C4ED0D6.4084AD3C@atosorigin.com>,
Jerome Grimbert <jer### [at] atosorigin com> wrote:
> Two...:
Not quite so bad, but still not good: put the incoming ray in the mesh
struct. There shouldn't be anything that bothers it while the normal
calculation is being done.
The best solution, but a pain to do.
Christopher James Huff <chr### [at] mac com>
In article <3c4ec167@news.povray.org>, Warp <war### [at] tag povray org>
> upper level, thus nullifying the inversion.
Yuck.
Any idea what the visual effects of this will be? I don't think it will
look correct. You will be seeing a surface with the normal pointing away
from you, I think that unless you toss an "fabs()" into the mix, you
will end up with negative diffuse values.
Hmm, using "fabs()" might be a better method than inverting the normal
anyway...
I still like my method: If the triangle normal is pointing towards you,
but the interpolated normal is pointing away, ignore the intersection
and the next one with the same object. The effect should be that you
just don't see the corners that you shouldn't be seeing...it might even
round out the outline a little.
This would probably be quite difficult to code, though...
Christopher James Huff <chr### [at] mac com> wrote:
: Any idea what the visual effects of this will be?
It will look correct (well, not 100% correct, but smooth triangle shading
is never 100% correct anyways).
: You will be seeing a surface with the normal pointing away
: from you
That doesn't matter because it's only used for the illumination, nothing
else.
: I think that unless you toss an "fabs()" into the mix, you
: will end up with negative diffuse values.
How so? From the point of view of the light source, nothing strange is
happening.
It should work correctly in the way I proposed.
And where do you propose to put the fabs()? I don't understand it.
: I still like my method: If the triangle normal is pointing towards you,
: but the interpolated normal is pointing away, ignore the intersection
: and the next one with the same object. The effect should be that you
: just don't see the corners that you shouldn't be seeing...it might even
: round out the outline a little.
This will result in big holes in the mesh in some cases (note that the
normal vectors at the vertices of the triangles do *not* necessarily have to
be the average of the adjacent triangle normals; they can be anything).
> The normal vector of this smooth triangle points always upwards, never
> downwards, and thus it should never get colored red. But the inversion
> phenomenon of the normal causes the artifact.
I can be completly offtopic but could be normal determined by order of vertices
in triangle?
ABX
On Thu, 24 Jan 2002 08:48:33 +0100, Włodzimierz ABX Skiba
>in triangle?
Then the renderer would have to trust that the order is correct, and
that is the task of either the export utility or the scene that
generates it. In any case the user shouldn't be doing the renderer's
job.
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
> > in triangle?
not exactly
I proposed this becouse I always generate meshes from triangles builded in one
direction (ok, almost always). I helps me a lot in generating smooth normals.
Old behaviour could be supported just with #version 3.1; afaik there is no
export utylity for 3.5 so I suppose all utilities adds #version to exported
scripts.
> In any case the user shouldn't be doing the renderer's job.
But renderer can't decide as I understand.
ABX
Włodzimierz ABX Skiba <abx### [at] babilon org> wrote:
: I can be completly offtopic but could be normal determined by order of vertices
: in triangle?
I didn't understand this.
The problem is not determining the normal. The problem is just that if
the angle between the incoming ray and the normal vector returned by the
object have an angle <90 degrees, the normal is inverted.
This works just fine in most cases (and it has to be done this way). The
only problem happens with smooth triangles and smooth heightfields in certain
cases.
As for lighting, this problem goes away by making the object
double-illuminated (because then it doesn't matter which way the normal
is pointing). However, as for the slope pattern, the solution is not so simple
(double_illuminate is used only for lighting and can't be used for slope
pattern calculation).
By the way: In a heightfield the problem with the slope y pattern goes
away if you "mirror" the color_map around 0.5 (of course it doesn't work if
the slope is anything else than y), besides making the heightfield
double-illuminated.
With smooth meshes which use the slope pattern there's no currently fix,
AFAIK.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
I see, sorry then.
ABX
Date: 24 Jan 2002 09:48:07
Message: <3C501EB7.263F96C0@atosorigin.com>
> in triangle?
From memory:
In 3.1 code, the short answer is NO, at least for mesh,
because the mesh code is free to reorder the vertices of any single triangle.(*)
So even if you carefully generate all your triangles with a +side and -side,
once in the mesh structure it might be impossible to get back to the original
order. It's often simpler to use a smooth_triangle which allow to explicitely
specify a normal for each vertex (but take more memory, of course).
(*) and it does it, according to its own private criteria.
Non Sine Numine
On Thu, 24 Jan 2002 13:38:00 +0100, Włodzimierz ABX Skiba
>not exactly
Yes, but that's you. You're not the average Joe User.
Yet :)
In article <9uuv4uoaebc3dldemv9snhjmopultmctlj@4ax.com>,
> job.
No. There is no way for the renderer to reliably determine the correct
normal, and such a mechanism would break many meshes that use the
winding to determine it. It normally isn't a problem anyway, since POV
renders both sides of the triangle.
And it isn't related to the height field problem, which has more to do
with the interpolation of smooth triangle normals.
In article <3C501EB7.263F96C0@atosorigin.com>,
> triangle.(*)
Not true. The mesh stores the vertex *vectors* separately, the triangles
then refer to that list. The triangles still know what order the
vertices are in.
Proof? Use interior_texture on a mesh. The height-field macros make good
examples...
Date: 6 Feb 2002 07:18:40
Message: <3c611f20@news.povray.org>
> macros make good examples...
And after I fixed the height-field macros you even get the interior texture
on the *inside*, contrary to how it was before... ;)
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Jan 20)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
