POV-Ray : Newsgroups : povray.beta-test : [std include] floats as vectors Server Time
2 Nov 2024 07:28:07 EDT (-0400)
  [std include] floats as vectors (Message 1 to 9 of 9)
Subject: [std include] floats as vectors
Date: 17 Jan 2002 08:17:40
Message: <vkhd4uoppr1vl1f6k0fvgnbhqbece3k7cb@4ax.com>
POV 3.5 b 10
It is possible to write floats as vectors in POV but somehow for standard
include files it can't be done. For example I can't write
  Round_Box(-1,1,.1,no)
I have to write
  Round_Box(<-1,-1,-1>,<1,1,1>,.1,no)
But it could be done with some simple additions. For example for Round_Box it
can be done with additional two lines at beginnig of macro:
   #local A=A+0*x;
   #local B=B+0*x;
This behaviour is connected with all macros with vector parameters. If there are
some problems with time or something I can check all standard macros for such
cases and post changed versions somewhere.
ABX
Subject: Re: [std include] floats as vectors
Date: 17 Jan 2002 10:03:47
Message: <3c46e7d3@news.povray.org>
it
>    #local A=A+0*x;
>    #local B=B+0*x;
Good idea.
Fabien.
Date: 17 Jan 2002 10:11:47
Message: <3c46e9b3$1@news.povray.org>
> it can be done with additional two lines at beginnig of macro:
>    #local A=A+0*x;
>    #local B=B+0*x;
Or by
#local A = A*<1,1,1>;
for that matter.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 17 Jan 2002 10:23:33
Message: <a0rd4u4m9q4h7a0ida1fs6918ml9k5uf6r@4ax.com>
On Thu, 17 Jan 2002 10:09:34 -0500, "Slime" <noo### [at] hotmailcom> wrote:
> >    #local A=A+0*x;
> >    #local B=B+0*x;
> Or by
> for that matter.
my version is shorter ;)
ABX
Date: 17 Jan 2002 10:37:31
Message: <Xns9199A95C9A5C1seed7@povray.org>
It's not a sig.
What version is faster?
Ingo
Date: 17 Jan 2002 10:43:39
Message: <m2sd4u8jnq3cjdtd3nv3umib7av0bjr7gc@4ax.com>
On 17 Jan 2002 10:37:31 -0500, ingo <ing### [at] homenl> wrote:
> in news:a0rd4u4m9q4h7a0ida1fs6918ml9k5uf6r@4ax.com W?odzimierz ABX Skiba
> It's not a sig.
but since macro calling is connected with seeking on file then it can be
important sometimes
imo it doesn't metter. it is not in loop and both return vector - it is most
important
ABX
Date: 17 Jan 2002 11:40:18
Message: <3c46fe71@news.povray.org>
: but since macro calling is connected with seeking on file then it can be
: important sometimes
  AFAIK the speed of seeking a file is independent of its size (as it just
modifies a file handler; it doesn't read the file).
Date: 17 Jan 2002 13:05:52
Message: <j24e4ukk3r4gmrqugkpo51brq2tlg8kn0k@4ax.com>
If there is still somebody interested then I've compared:
script 1:
      0: #local X=1;
      1: #local Y=X+0*x;
      2: #local Y=X+0*x;
 114688: #local Y=X+0*x;
script 2:
      0: #local X=1;
      1: #local Y=X*<1,1,1>;
      2: #local Y=X*<1,1,1>;
 114688: #local Y=X*<1,1,1>;
Each one was started five times with +w1 +h1.
Average total CPU time used reported by NT version for first script was
5.178 s.
Average total CPU time used reported by NT version for second script was
8.790 s.
Done on PII 233 with 128 MB on NT 4 Sp 6
So first one is much faster. IMO becouse of smaller number of parsed tokens.
Good night (and morning for others).
ABX
Date: 17 Jan 2002 18:17:16
Message: <chrishuff-F03E98.18180817012002@netplex.aussie.org>
In article <vkhd4uoppr1vl1f6k0fvgnbhqbece3k7cb@4ax.com>,
 W?odzimierz ABX Skiba <abx### [at] babilonorg> wrote:
>    #local A=A+0*x;
>    #local B=B+0*x;
I had intended to work around this problem by using
#local A = A + o;
in all those macros, but never got around to it...
No reason to use things like "*< 1, 1, 1>" or "+ 0*x" when "o" (for
"origin") is defined in consts.inc as < 0, 0, 0>. ;-)
