POV-Ray : Newsgroups : povray.beta-test : [Windows] Save As... with same filename doesn't work Server Time
11 Jun 2026 18:57:32 EDT (-0400)
  [Windows] Save As... with same filename doesn't work (Message 1 to 4 of 4)
Subject: [Windows] Save As... with same filename doesn't work
Date: 15 Jan 2002 10:23:42
Message: <3c44497e$1@news.povray.org>
I'm not sure whether this is really a bug, but I'll mention it anyway. If
you go to File > Save As... and save the file with the same filename it
already has, it says: "This file is already open in the editor."
POV-Ray 3.5 beta 10, Windows 98 SE.
light_source{6#local D#macro B(E)#macro A(D)#declare#declare C=mod(E
D);E=(E-C)/D;C#end#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(C<3)
}cylinder{0(C=<1 2>).2translate<D+C*A(2)A(4)#else}intersection{torus
{1 .2}box{-2y}rotate<1 0C>*90translate<D+1A(2)*2+1#end-2 13>pigment{
rgb x}finish{specular 1}#end#end#end=-8;1B(445000298)B(519053970)B(
483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)}
Subject: Re: [Windows] Save As... with same filename doesn't work
Date: 16 Jan 2002 00:02:08
Message: <3c450950@news.povray.org>
"Anders K." <and### [at] prostard2gcom> wrote in message
news:3c44497e$1@news.povray.org...
I'd fix this if I could work out why users would want to 'save as' a file with
its existing filename.
-- Chris
Date: 16 Jan 2002 01:08:19
Message: <3C451844.4050100@skynet.be>
Because you've mistakenly selected "save as" instead of "save", and
doesn't want to go back :-)
Fabien.
Date: 16 Jan 2002 07:30:06
Message: <3c45724e@news.povray.org>
In which case the error message 'file is already open in editor' is
entirely correct ;)
seriously, if I happen to be working on the editor one day I may fix
this (if I remember).
-- Chris
