POV-Ray : Newsgroups : povray.beta-test : VC or the other one? Server Time
11 Apr 2026 05:43:18 EDT (-0400)
  VC or the other one? (Message 1 to 10 of 13)
Subject: VC or the other one?
Date: 15 Jan 2002 09:08:51
Message: <3c4437f3$1@news.povray.org>
What is the difference between the VC compile and the other one? Is one
faster/slower/less stable/more stable/comes with a tasty chocolate coating?
Enquiring minds want to know....
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Subject: Re: VC or the other one?
Date: 15 Jan 2002 09:14:28
Message: <v4e84ucgc2nivqcgs05bhguni86ff7huk9@4ax.com>
On Tue, 15 Jan 2002 14:08:51 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
different compiler
> Is one faster/slower/less stable/more stable ?
afaik it is available to answer this question
ABX
Date: 15 Jan 2002 09:30:31
Message: <3c443d07@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
: What is the difference between the VC compile and the other one?
  The Intel compile should be faster.
Date: 15 Jan 2002 09:59:38
Message: <3c4443da$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3c443d07@news.povray.org...
Umm, which is the Intel compile?
Date: 15 Jan 2002 10:04:20
Message: <a4h84ukpjt6saorsl5nffh5r2t55d29nd7@4ax.com>
On Tue, 15 Jan 2002 14:59:38 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
Default one.
It is written in third line of message window after start.
Additional version (VC) is available since beta 7.
ABX
disc{z,-z 5#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;pigment{#local g=function(_){ceil(_)-_}function#local//X
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e>0)<O(),O()//AB
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//POV35
Date: 15 Jan 2002 10:11:55
Message: <3c4446bb$1@news.povray.org>
news:a4h84ukpjt6saorsl5nffh5r2t55d29nd7@4ax.com...
> Default one.
Yes, but there is nothing to say that VC != intel compile, so it's still a
source (sic) of confusion to the compile-challenged.... Ta, for the info.
Date: 15 Jan 2002 10:22:40
Message: <50i84usdlocmt5f7s3nsraqeqhkispaeto@4ax.com>
On Tue, 15 Jan 2002 15:11:57 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
Afaik Intel is manufacturer of compiler and not name of target platform :-)
Both compiler version should work with Athlon imo :-)
http://msdn.microsoft.com/visualc/
http://www.intel.com/software/products/compilers/c50/index.htm
ABX
Date: 15 Jan 2002 10:23:10
Message: <3c44495e@news.povray.org>
In article <3c4446bb$1@news.povray.org> , "Tom Melly" <tom### [at] tomandlucouk>
No, for the logical-challanged :-)
If you have two things and you have two, and only two names, and you know
that each thing has to have one unique name, and you know the unique name of
one of the things, the only logical name for the other thing is the only
name remaining because that will be the only unique name left to give the
other thing.  Thus, logic dictates that one of the compiles has the name
"VC" and one the name "Intel".
    Thorsten
Date: 15 Jan 2002 10:33:12
Message: <3c444bb8$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c44495e@news.povray.org...
Good logic, but bad reality/semantics. I have a choice of two docs, one in
microsoft format, one not specified. One document identifies itself as a Word
document, therefore the other document must be the microsoft one.
In other words, I have no way of knowing that Intel's compiler isn't called VC.
Date: 15 Jan 2002 11:17:30
Message: <3c44561a@news.povray.org>
: In other words, I have no way of knowing that Intel's compiler isn't called VC.
  But everyone knows that VC (ie. Visual C++) is a compiler made by Microsoft,
while the Intel compiler is a compiler made by Intel. They are two totally
different programs and have nothing in common (except that they both compile
C/C++ programs).
  The Intel compiler can optimize better for modern PC processors than the VC
compiler can.
