POV-Ray : Newsgroups : povray.beta-test : [linux] Rendering without display on the console. Server Time
11 Jun 2026 18:56:50 EDT (-0400)
  [linux] Rendering without display on the console. (Message 1 to 6 of 6)
Subject: [linux] Rendering without display on the console.
Date: 11 Jan 2002 10:53:36
Message: <3c3f0a80@news.povray.org>
Hi:
  First, many thanks Mark! Your beta distribution tgz worked finely here,
and the first tests traced without any problem. But when I tried at night
to let it rendering without X, from the console, I got the following error,
even with -d in the command line:
svgalib: Configuration file 'etc/vga/vgalib.confing' not found.
svgalib: Assuming Microsoft mouse.
svgalib: Assuming low end SVGA/8514 monitor (35.5 KHz).
svgalib: Cannot get I/O permissions.
  Let me know if I forgot to mention something or you want any more info.
Beta 9 running on AMD 1.2Ghz, 512MB RAM, Linux R.H.7.2, XFree 3.3.6.
Jaime Vives Piqueres
http://www.ignorancia.org
Subject: Re: [linux] Rendering without display on the console.
Date: 11 Jan 2002 11:15:04
Message: <3C3F0FEB.CAC9DDC4@atosorigin.com>
What was the user id ? (root or not ?)
Shouldn't it be "+D" to disable the display ?
Non Sine Numine
http://grimbert.cjb.net/
Date: 11 Jan 2002 11:17:20
Message: <9u3u3uolqv7gp8l006aggl7uauj7fftl2r@4ax.com>
On Fri, 11 Jan 2002 17:16:43 +0100, "J. Grimbert"
"-D" ?
(5.2.2.2.1)
ABX
Date: 11 Jan 2002 13:02:58
Message: <3c3f28d1@news.povray.org>
  User "jaime": I do not use root to trace, of course!
  No. Every option which is turnable on/off, accepts +/-option to turn it
on/off. In fact, the error message would have been logic if I were using +D
(which is the default).
Date: 11 Jan 2002 13:08:32
Message: <3c3f2a20@news.povray.org>
> "-D" ?
> (5.2.2.2.1)
  Yes, -D. What's wrong?
Date: 12 Jan 2002 11:15:55
Message: <3c40613b@news.povray.org>
Thanks for finding this.  The fix will be in the next beta.  The
workaround in the meantime is to telnet or ssh to localhost, since it
only uses svgalib if you're on a console.
-Mark Gordon
In article <3c3f0a80@news.povray.org>, "Jaime Vives Piqueres"
<jai### [at] ignoranciaorg> wrote:
> Hi:
>   here,
> night to let it rendering without X, from the console, I got the
> following error, even with -d in the command line:
> svgalib: Configuration file 'etc/vga/vgalib.confing' not found. svgalib:
> svgalib: Assuming low end SVGA/8514 monitor (35.5 KHz). svgalib: Cannot
>   info.
