POV 3.5 b 9.icl on PII 233 128 MB with NT 4 Sp 6
"CPU time used ..." message not appear in output stream when +GAfilename.txt
option was used (warning level is highiest as default).
ABX
Subject: Re: [win] cpu time not in stream
Date: 10 Jan 2002 00:00:52
Message: <3c3d2004@news.povray.org>
> "CPU time used ..." message not appear in output stream when +GAfilename.txt> option was used (warning level is highiest as default).
This is a message from the Windows code. It is not related to any of the POV
render streams.
-- Chris
On Thu, 10 Jan 2002 01:58:43 +1100, "Chris Cason"
<newsadmin-despam-@povray-no-spam.org> wrote:
> > "CPU time used ..." message not appear in output stream when +GAfilename.txt> > option was used (warning level is highiest as default).>> This is a message from the Windows code.
So no chance ?
> It is not related to any of the POV> render streams.
It fits in the "Statistic" stream definition according to 5.2.5.1 for me. It is
not very flexible to copy it via Copy Pane when rest of long output is
redirected properly.
ABX
Date: 10 Jan 2002 07:53:11
Message: <3c3d8eb7@news.povray.org>
> It fits in the "Statistic" stream definition according to 5.2.5.1 for me. It is> not very flexible to copy it via Copy Pane when rest of long output is> redirected properly.
No output generated by the windows code - of any sort - is ever included in the
statistics stream.
I suppose I could make an exception in this case, if it isn't too hard for me to
do. Let me look into it.
-- Chris
On Thu, 10 Jan 2002 23:51:39 +1100, "Chris Cason"
> I suppose I could make an exception in this case, if it isn't too hard for me to> do. Let me look into it.
Thank You
ABX
