POV-Ray : Newsgroups : povray.beta-test : crash with some boxes /infinite boxes Server Time
13 Oct 2025 01:35:13 EDT (-0400)
  crash with some boxes /infinite boxes (Message 1 to 4 of 4)
Subject: crash with some boxes /infinite boxes
Date: 5 Jan 2002 15:09:06
Message: <3c375d62$1@news.povray.org>
Hi!
I'm a bit puzzled by this one:
If you render the scene below, win98 gives me the typical crash-dialog (this
application will be closed ...). In fact, povray is still running (creating
boundingslabs) and reacts (you can use the editor...
Furthermore it sais:
"Scene contains 299 frame level objects; 44 infinite"
"Reallocing Finite to 765"
I don't have infinite objects, just boxes. And I don't know what the second
sentence means.
If you uncomment the second #declaration of Alpha, povray runs, but the
shadows are missing/wrong, and I got strange messages as well:
"Scene contains 299 frame level objects; 43 infinite."
"Reallocing Finite to 768"
Uncommenting the third #declaration you get what I expected.
Still 44 infinite., but no "Reallocing"
If you change Depth you get different results. I got the Alphas with trial
and error.
This only happens with the intel-compile! the msvc one is working
fine.(still, there are the infinite objects but the results are as expacted)
AMD 1.4GHz, Ram:512MB DDR, OS: Win98
///begin
#declare Depth = 300;
#declare Alpha = 36; ///crash
///#declare Alpha = 36.18; ///wrong
///#declare Alpha = 33.3; ///ok.
#local Fak = cos(radians(Alpha))+sin(radians(Alpha));
object {
 #local G = 1;
 #local D = 2;
 #local Translater = 0;
 #local Rotater =0;
 union {
  #while (D<=Depth)
   box {-<G/2, -G/2, -G/2>
         <G/2, -G/2, -G/2>
    rotate y*Rotater
    translate -y*Translater
   #local Translater = Translater + G/2;
   #local G = G * Fak;
   #local Rotater = Rotater + Alpha;
   #local D = D + 1;
 pigment {color rgb 1}
 location <0,5,0>
 look_at 0
light_source {
 <0,1,-1>*20
 color 1
///end
Subject: Re: crash with some boxes /infinite boxes
Date: 5 Jan 2002 23:00:26
Message: <T3MjCGANu8N8Ewhv@econym.demon.co.uk>
Wasn't it KalleK who wrote:
>Hi!
>sentence means.
I confirm all this, but note:-
The editor is still running when the renderer has crashed, but it
doesn't receive any status updates from the dead renderer, so it has no
way of knowing that the renderer isn't still creating bounding slabs.
This always happens when the renderer crashes.
I notice that POV considers an unrotated box to be "infinite" if it is
larger than 2714 pov-units. E.g.
     #local G = 2715;
     box {-G/2,G/2}
Is counted as an infinite object.
Thus, if you comment out the "rotate y*Rotater" line from KalleK's
scene, you get
     Scene contains 299 frame level objects; 274 infinite.
since all the boxes larger than 2714 are counted as infinite.
Now, 230 of these boxes are *not* considered infinite. This seems to be
related to the rotation. E.g. the largest box is
   #local G = 17791297395961415000000000000000000000000000;
   #local Rotater = 10728;
   box {-G/2,G/2 rotate y*Rotater}
Is not counted as infinite
A simpler scene, directly using the calculated values from KalleK's
scene, that exhibits the crash. (With only 10 boxes there's no crash)
camera { location <0,5,0> look_at 0}
light_source { <0,1,-1>*20 color 1}
Mike Williams
Gentleman of Leisure
Date: 15 Jan 2002 00:25:46
Message: <3c43bd5a@news.povray.org>
KalleK wrote in message <3c375d62$1@news.povray.org>...
>sentence means.
POV-Ray considers an object to be infinite if its bounding box has a volume
larger than 20,000,000,000 units.
Mark
Date: 15 Jan 2002 12:15:20
Message: <3c4463a8@news.povray.org>
Well, I felt stupid after posting (at least concerning the infinte part), but
then Mike Williams discovered another oddness with those infinite things
concerning rotating them. Just have a look at his answer to my original post.
cukk
