POV-Ray : Newsgroups : povray.beta-test : file input - doc bug, i/o bug or tom bug? Server Time
6 Mar 2026 17:41:34 EST (-0500)
  file input - doc bug, i/o bug or tom bug? (Message 1 to 10 of 13)
Subject: file input - doc bug, i/o bug or tom bug?
Date: 4 Jan 2002 09:05:31
Message: <3c35b6ab@news.povray.org>
According to the docs (6.2.3.4)
"hello", 1,2
ought to be a valid input line from a file (string, float, float)
However, this generates an error, which is fixed by:
"hello", 1,2,
(requires final comma)
2.5.beta9.icl.win32
running Win2000, P3 733
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Subject: Re: file input - doc bug, i/o bug or tom bug?
Date: 4 Jan 2002 09:16:41
Message: <12eb3usbtoehrsumk43ejs5h203dbl4gh7@4ax.com>
On Fri, 4 Jan 2002 14:05:30 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
> According to the docs (6.2.3.4)  "hello", 1,2 ought to be a valid input line from a
> However, this generates an error, which is fixed by: "hello", 1,2, (requires final
comma)
works according to doc for me
do you read in loop ? perhaps there is one extra reading according to your while
condition
check this source
#fopen wfile "nothing.txt" write
#write( wfile , chr(34) , "hello" , chr(34) , ",1,2" )
#undef wfile
#fopen wfile "nothing.txt" read
#read( wfile , S, F1,F2 )
#warning S
#warning str(F1,0,0)
#warning str(F2,0,0)
> 2.5.beta9.icl.win32
please upgrade to 3.5 ;-)
ABX
Date: 4 Jan 2002 09:28:38
Message: <3c35bc16$1@news.povray.org>
news:12eb3usbtoehrsumk43ejs5h203dbl4gh7@4ax.com...
while
> condition
> check this source
Hmm, that's okay, but this version fails without a comma (e.g. ",1,2,\n")
#write( wfile , chr(34) , "hello" , chr(34) , ",1,2\n" ) /* bad */
/* #write( wfile , chr(34) , "hello" , chr(34) , ",1,2,\n" )*/ /* good */
#undef wfile
#warning S
#warning S
Date: 7 Jan 2002 05:35:10
Message: <3C397B3D.8070702@reading.ac.uk>
Hi Tom,
This is because a line-feed is not counted as an item separator, only commas are.
Bye for now,
	Mike Andrews.
Date: 7 Jan 2002 05:53:10
Message: <pbvi3uomd9n7427fp390jbr9mpvmsqjutg@4ax.com>
On Mon, 07 Jan 2002 10:41:01 +0000, Michael Andrews <M.C### [at] readingacuk>
But why you need separator after third component when you end reading at this
third component ? "\n" is only white space.
ABX
Date: 8 Jan 2002 05:20:36
Message: <3c3ac7f4$1@news.povray.org>
"Michael Andrews" <M.C### [at] readingacuk> wrote in message
news:3C3### [at] readingacuk...
> Hi Tom,
are.
Hmm, yes I realise that - all I can say is that I have never come across a
scripting lang. that behaves in this way. Could someone confirm that this is the
way that POV is meant to behave. If it is, then I would suggest some
clarification in the docs, since this will confuse Perl users for a start....
Date: 8 Jan 2002 05:22:25
Message: <3c3ac861@news.povray.org>
news:pbvi3uomd9n7427fp390jbr9mpvmsqjutg@4ax.com...
It would appear that in some ways POV is behaving as though it is globbing the
whole input file in one operation, and yet it isn't. Could someone confirm that
this is the intended behaviour?
Date: 10 Jan 2002 05:25:33
Message: <3c3d6c1d$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3c3ac7f4$1@news.povray.org...
<snip>
Hmm, no further comment. Anyone want to confirm whether this is a bug or not?
Date: 10 Jan 2002 08:52:20
Message: <3C3D9E00.9040808@reading.ac.uk>
Hi Tom,
Well, it seems to be doing exactly as it should, to me.
Outputting lines 3 & 4 of your test code 'nothing.txt' is
"hello",1,2,
"hello",1,2
which is read correctly.
With lines 2 & 4 you get
"hello",1,2
"hello",1,2
which causes a parsing error when it tries to read the second "hello"
because it is not preceded by a comma.
So IMHO this works as given in the documentation (ss6.2.3.3).
Bye for now,
	Mike Andrews.
Date: 10 Jan 2002 09:09:27
Message: <508r3u40rqiiutrm7bpg10rrtm1um9nejj@4ax.com>
On Thu, 10 Jan 2002 13:58:24 +0000, Michael Andrews <M.C### [at] readingacuk>
I have rechecked all scripts from this thread and all works for me as expected,
but I remember there was something wrong imo.
Btw: there is general rule that commas are optional but it probably applies only
to script.
ABX
