POV-Ray : Newsgroups : povray.beta-test : Problem with #read Server Time
30 Sep 2024 21:29:28 EDT (-0400)
  Problem with #read (Message 1 to 7 of 7)
Subject: Problem with #read
Date: 2 Jan 2002 20:35:25
Message: <3c33b55d@news.povray.org>
Don't know if this is a bug but it seems to be a somehow strange behavior.
Try to render this and you will see what I mean.
#fopen wfile "nothing.txt" write
#fopen rfile "nothing.txt" read
#read(rfile,ahh)
#ifdef(ahh)
#local ohh=ahh;
433 Celeron Win 98 SE POV 3.5 beta 9
#local T=text{ttf"timrom.ttf""Simon Adameit".01,0}#local Y=1;#while(Y>-1)
#local X=0;#while(X<7)#local O=trace(T<X,Y><X,Y>+z);cylinder{<X-3,Y,5>*.01
<X-3,Y,5>*.01+5e-3,5e-5pigment{rgb 25*O}}#debug chr(83-(O.x=0)*51)#local
X=X+.05;#end#debug"\n"#local Y=Y-.05;#end
Subject: Re: Problem with #read
Date: 3 Jan 2002 06:52:32
Message: <5vg83u03fdm9i1iebk1spur4ba0stfbs0k@4ax.com>
On Thu, 3 Jan 2002 02:32:02 +0100, "Simon Adameit" <gom### [at] gmxde> wrote:
You shouldn't expect that bug appear the same on every computer. It is possible
that behaviour depends on platform, compilation version, processor. So instead
of "you will see" please solve riddle in report and allow confirmations. This
bug is probably connected with IO things and they can be different on
Mac/Win(/UNIX) platforms.
> #local ohh=ahh;
yes, strange behaviour,
  #local ohh=ahh <----ERROR
  Parse Error: Cannot assign uninitialized identifier.
was returned
POV 3.5 b 9 on PII 233 128 MB with NT 4 Sp 6
ABX
Date: 3 Jan 2002 07:35:11
Message: <3c344fff@news.povray.org>
possible
instead
This
You're right, wont happen again if I have the "luck" to find a bug.
> > #local ohh=ahh;
> was returned
This aslo happens if you use #if(defined(ahh)) instead of #idef(ahh)
Date: 3 Jan 2002 09:37:01
Message: <B85A2B1A.2813%cwalther@gmx.ch>
> ...This bug is probably connected with IO things and they can be different on
> was returned
I can confirm that the same thing happens with the Mac version (3.5b9, MacOS
9.2.2, PPC G3 266, 192MB RAM).
It seems that "defined" and "initialized" is not the same thing, and you
just found a way to make an identifier that is defined but not initialized.
From the fact that there's a special parse error message for that, it seems
that the possible existence of uninitialized identifiers was foreseen by the
programmers, so it wouldn't be a bug.
Date: 3 Jan 2002 09:59:08
Message: <v0s83u42e3mqgn9eljrdba4i9iocoiepcp@4ax.com>
On Thu, 03 Jan 2002 15:36:59 +0100, Christian Walther <cwa### [at] gmxch> wrote:
IMO there is some kind of bug. When you read ten variables from file but there
is nine in file then after ninth reading file handle is udefined (according to
6.2.3.3). So you can simple check EOF. But when you open empty file for reading
then handle should be undefined at begining or some warning/error could be
generated.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 3 Jan 2002 12:16:42
Message: <3c3491fa@news.povray.org>
Note that in your code, you are testing whether the variable "aah" is
defined, rather than the file handle. However, the following code gives the
same error message:
#ifdef(rfile)
  #read(rfile,ahh)
  #local ohh=ahh;
Anders
light_source{6#macro A(B)#declare C=mod(E B);#declare E=(E-C)/B;C#end
#macro B(E)#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(C<3)cylinder
{0(C=<1 2>).2translate<D+C*A(2)A(4)#else intersection{torus{1 .2}box{
-y 2}rotate<-1 0C+1>*90translate<D+1A(2)*2+1#end-2 13>finish{specular
1}pigment{red 1}}#end#end#end#local D=-8;1}B(445000298)B(519053970)B(
483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)
Date: 3 Jan 2002 12:30:29
Message: <j0593uo3n5jl1etbf8b1u5cv9r604roosv@4ax.com>
On Thu, 3 Jan 2002 12:16:40 -0500, "Anders K." <and### [at] prostard2gcom> wrote:
Note it's not mine code :-)
Handle is tested by read, read not work with undefined handle.
ABX
