POV-Ray : Newsgroups : povray.beta-test : CSG difference with text Server Time
18 May 2026 18:25:44 EDT (-0400)
  CSG difference with text (Message 11 to 16 of 16)
Subject: Re: CSG difference with text
Date: 1 Jan 2002 17:49:33
Message: <3c323cfd@news.povray.org>
"Thorsten Froehlich" wrote:
> Of course one could change it to some extend at the
> serve penalty of *much* slower rendering.
I don't think it's worth it. The user can always intersect the text object
with a plane to avoid the problem.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 2 Feb 2002 03:31:51
Message: <DyP3zCAt$5W8EwL9@econym.demon.co.uk>
Wasn't it Francois Labreque who wrote:
>Thorsten Froehlich wrote:
>> In article <3c304eaf@news.povray.org> , "Felix Wiemann"
>> <Fel### [at] gmxnet> wrote:
>>>But the left part of the letter "P" is cut of. It seems to be a
>>>bounding problem.
>> You may want to check if the font comes with correct bounds for its
>> charaters in a font editor.
>As mentioned in my other post, this happens with other fonts as well.  I
>dont think it is dues to the bounding of the font itself as the problem
>is in the Z direction.  Testing with a modified scene shows that the
>problem is that the text isn't "straight".  See image in p.b-t.b.
>#include "colors.inc"
>camera{
>     location < 10, 15, -20 >
>     look_at < 10, 0 0 >
>plane{
>     y, 0
>     pigment{ White }
>union{
>     box{
>         < -5, -1, 0 > < 25, 20, 20 >
>         pigment{ Gray50 }
>     text{
>         ttf "timrom" "POV" 0.1 0
>         scale < 10, 10, 100000 >
>         pigment{ Red }
>light_source{
>     < -15, 50, -15 >
>     White
I see that Thorsten now claims that this is a coincident surfaces
problem. I must say it doesn't look like that to me.
I've checked all the other pov primitives, and nothing else is tilted in
this way.
Mike Williams
Gentleman of Leisure
Date: 2 Feb 2002 03:46:40
Message: <3c5ba76f@news.povray.org>
To me it just seems to be some accuracy problem. The accuracy problem gets
more visible when scaling with a huge number.
Date: 2 Feb 2002 04:10:42
Message: <3c5bad12$1@news.povray.org>
In article <DyP3zCAt$5W8EwL9@econym.demon.co.uk> , Mike Williams
Given the description of the original bug without having the font, this was
the only possible conclusion.  Essentially these two problems need to be
treated as two distinct problems.  The only one that can be reproduced is the
one using timrom.ttf because if or if there is not a problem with the original
font cannot be determined without having the font.  I can only explain
something I can actually test.
Investigating the given example with the timrom.ttf font revealed that at
least in that case it is.  It has to do with the scale, which, lets say has
'some effects on the ray' that basically make a difference of about 10e-5,
which for the text object is enough to cause problems.
    Thorsten
e-mail: tho### [at] trfde
Date: 2 Feb 2002 07:06:02
Message: <3c5bd62a@news.povray.org>
has
As Rune said, it is possible to avoid the overlapping letters problem by
intersecting the text with a plane, but the tilted text problem appears
still when it's intersected. Even if it is only a coincident surfaces
problem, why do you say that it's not a bug? There is no proper workaround
except less scaling (and that's not a workaround but a restriction IMHO).
Date: 2 Feb 2002 08:05:03
Message: <3c5be3ff@news.povray.org>
In article <3c5bd62a@news.povray.org> , "Felix Wiemann"
The coincident surface problem is not a bug...
Whatever you call it, floating-point number precision is the way it is and
there is nothing anybody can do about it.
BTW, a much better solution to this is to split the text into two/three
sections.  Simply make one/both ends out of a text scaled by 1, and then place
the a extremely scaled version in the middle (so it overlaps a bit) and merge/
union the whole thing together.  It will of course slow down rendering a bit,
but it won't be as much as using a plane and CSG (without manual bounding).
    Thorsten
