POV-Ray : Newsgroups : povray.beta-test : Quality options in docs Server Time
31 Mar 2026 09:54:32 EDT (-0400)
  Quality options in docs (Message 1 to 6 of 6)
Subject: Quality options in docs
Date: 30 Dec 2001 13:18:36
Message: <3c2f5a7c@news.povray.org>
Is section 5.2.6.1 up to date?
Subject: Re: Quality options in docs
Date: 30 Dec 2001 14:44:01
Message: <Xns9187D3200B70Cseed7@povray.org>
Don't think so. I asked the same question during pre-beta testing but got
no anwser.
Where do photons fit in in this list?
It says the default setting is 9, shouldn't that be something like:
"... the default setting is 9, unless media, photons or radiosity is used
in the scene. Then the default is autmaticaly adjusted."
Ingo
Date: 30 Dec 2001 15:43:46
Message: <3c2f7c82@news.povray.org>
In article <Xns### [at] povrayorg> , ingo <ing### [at] homenl>
It is the other way around.  Photons and radiosity require the correct
quality setting (9) and will be disabled automatically if the quality
setting is less!  Media works just like in 3.1.
    Thorsten
e-mail: tho### [at] trfde
Date: 30 Dec 2001 15:49:43
Message: <3c2f7de7@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: It is the other way around.  Photons and radiosity require the correct
: quality setting (9) and will be disabled automatically if the quality
: setting is less!  Media works just like in 3.1.
  But which is the new minimum quality where radiosity (and photons) do
work? They work with quality 9, so it must be that or something lower.
This part of the documentation needs updating.
Date: 30 Dec 2001 16:07:44
Message: <3c2f8220@news.povray.org>
In article <3c2f7de7@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> : Photons and radiosity require the correct quality setting (9) and will
> : be disabled automatically if the quality setting is less!
It is 9, as I said.  If it isn't 9 you get a warning message (hopefully)
that tells you they have been disabled automatically because of the too low
quality setting.
    Thorsten
Date: 30 Dec 2001 18:55:26
Message: <Xns918899C68BD5seed7@povray.org>
I'll make the changes to the doc.
Ingo
