POV-Ray : Newsgroups : povray.beta-test : Random crashes with W2000/Athlon Server Time
18 Dec 2025 19:15:53 EST (-0500)
  Random crashes with W2000/Athlon (Message 1 to 6 of 6)
Subject: Random crashes with W2000/Athlon
Date: 29 Dec 2001 09:15:48
Message: <3c2dd014@news.povray.org>
I get random crashes on a AMD Athlon 1.33 / W2000 SP1.
The scene works fine with my usual PIII 733 / NT4 SP6.
The first renders goes fine, then after several runs Povray crashes.
I haven't tried yet to simplify the scene to create a demo scene for this
(which could take some time) but has anyone got this problem before ?
Povray 3.5 beta 9 intel compile
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Subject: Re: Random crashes with W2000/Athlon
Date: 29 Dec 2001 21:34:26
Message: <43vs2u8nq9258nohp93rfo2efa5locp0f6@4ax.com>
Hi, Gilles. Any random crashes with earlier betas using the same scene on
the same machine? What happens if you use the optional VC++ compile?
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
Date: 30 Dec 2001 13:03:14
Message: <3c2f56e2$1@news.povray.org>
43vs2u8nq9258nohp93rfo2efa5locp0f6@4ax.com...
on
I didn't test it with the previous betas (I just got the machine).
The VC++ compile of the beta 9 crashes too. Actually it crashed the first
time I tried to render the scene with it... Note than a perhaps related
problem is that sometimes the editor returns a "failed to write" message on
the current scene. It seems to happen after Povray is reloaded after a
crash, but not always. The file is freed again after a few minutes.
I have a simplified version of the scene that used to crash but right now it
doesn't...
BTW, the spline bug I reported on Dec 22 is also visible on the VC++ version
(I can almost make it repeatable now). I thought first that both problems
(spline and crash) were related but they are not.
G.
- Posters
Date: 31 Dec 2001 13:25:22
Message: <3c30ad92@news.povray.org>
Odd .. I'm using WinXP right now on an Athlon - upgraded this weekend from
Win98.  So far, no crashes.
I'd be willing to try your scene to see if it's machine specific.
                  == John ==
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3c2dd014@news.povray.org...
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 19 Jan 2002 11:20:04
Message: <3c499cb4$1@news.povray.org>
For Info, we got similar crashes (due to failure to write) when using
DevStudio (so totally non-PovRay related) using w2k on intel boxes.  I
suspected the defrag program which was running in the background initially,
but removing that from the system did not cure the problem.. It occurred on
3 out of ten boxes with alarming regularity.
I suspect something a lot more sinister than PovRay is to blame for this
problem :)
Pat Parslow
(happy to be at home using 9x)
news:3c2f56e2$1@news.povray.org...
news:
> on
on
it
> doesn't...
version
> G.
> - Posters
this
Date: 22 Jan 2002 10:10:09
Message: <3c4d80d1@news.povray.org>
"Pat Parslow" <pat### [at] parslowtele2couk> wrote in message
news:3c499cb4$1@news.povray.org...
<snip>
Possible related W2K problem is that sometimes I am not allowed to delete a pov
file externally even when I have closed the file in pov. Generally, I have to
close pov before I can delete the file.
