POV-Ray : Newsgroups : povray.beta-test : crash with loop Server Time
2 Nov 2024 09:20:15 EDT (-0400)
  crash with loop (Message 1 to 6 of 6)
Subject: crash with loop
Date: 28 Dec 2001 13:28:07
Message: <3c2cb9b7@news.povray.org>
The following code crashes POV
#local Z=0;
#while(Z<1)
#local
433 Celeron 64 MB Windows 98 SE POV beta 9
#local T=text{ttf"timrom.ttf""Simon Adameit".01,0}#local Y=1;#while(Y>-1)
#local X=0;#while(X<7)#local O=trace(T<X,Y><X,Y>+z);cylinder{<X-3,Y,5>*.01
<X-3,Y,5>*.01+5e-3,5e-5pigment{rgb 25*O}}#debug chr(83-(O.x=0)*51)#local
X=X+.05;#end#debug"\n"#local Y=Y-.05;#end
Subject: Re: crash with loop
Date: 28 Dec 2001 13:42:08
Message: <sjep2ucv0jrdi5jto9vk67gr2sp521cdhc@4ax.com>
On Fri, 28 Dec 2001 19:27:25 +0100, "Simon Adameit" <gom### [at] gmxde> wrote:
I can confirm this
POV 3.5 b 9 on PII 233 128 MB with NT 4 Sp 6
> #local Z=0;
> #while(Z<1)
> #local
> #end
I want refresh another win editor problem (listed in known bug list):
1. remove first line and save, current script is:
    #while(Z<1)
    #local
    Parse Error: Expected 'numeric expression', undeclared identifier 'Z' found
instead
2. Ctrl+Z back removed line and remove second line (arrow down, shift+arrow
down+del), current script is:
    #local Z=0;
    #local
instead
Seems editor not checked that content of windows is changed.
ABX
Date: 29 Dec 2001 11:04:00
Message: <7WA5KBAlHdL8Ewmn@econym.demon.co.uk>
>    #while(Z<1)
>    #local
>    #end
>instead
>    #local Z=0;
>    #local
>    #end
>instead
I confirm that this happens. The "save" icon is greyed out (presumably
because the editor is convinced that the text hasn't changed) you have
to use Ctrl-S or the File->Save menu to force it to be saved.
Does CodeMax have its own known bug list where this is listed? I'm
pretty sure it's never been in my POV known bug list.
Mike Williams
Gentleman of Leisure
Date: 31 Dec 2001 02:23:33
Message: <48403u81h40uim3egul58vj1f679dmbg10@4ax.com>
On Sat, 29 Dec 2001 14:23:33 +0000, Mike Williams <mik### [at] nospamplease> wrote:
> I'm pretty sure it's never been in my POV known bug list.
You have listed it as:
First report from bugreports
http://news.povray.org/u12outsm2kso3k5ef4lp26ogm5cvsm46ge@4ax.com
Just check this post: there are three listed. I don't know why but you never
unrolled this list. Seems only first is fixed now as Rune reported.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 2 Jan 2002 14:02:06
Message: <3c33592e$1@news.povray.org>
"Simon Adameit" <gom### [at] gmxde> wrote in message
news:3c2cb9b7@news.povray.org...
> #local Z=0;
> #while(Z<1)
> #local
> #end
Ain't that an infinite loop?
Date: 2 Jan 2002 16:13:15
Message: <slrna36tve.1rp.ron.parker@fwi.com>
>> #local Z=0;
>> #while(Z<1)
>> #local
>> #end
Yes, but it's worse than that.  It's essentially the same as if you wrote
a file that was just #local #local #local #local #local ad infinitum, with
the result that the parser stackfaults.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
