POV-Ray : Newsgroups : povray.beta-test : Function (optimization?) bug Server Time
31 Mar 2026 09:55:40 EDT (-0400)
  Function (optimization?) bug (Message 1 to 10 of 13)
Subject: Function (optimization?) bug
Date: 24 Dec 2001 23:14:33
Message: <3c27fd29$1@news.povray.org>
Try the below code.
'funciton{-y/1/2}' should be same as 'function{-y/1/(2)}'.
But it behaves differently.
(On the other hand, 'function{y/1/2}' is same as 'function{y/1/(2)}'.)
POV Win Beta 9, Win-Me
R. Suzuki
#version 3.5;
camera { location  z*-20 direction 3*z}
light_source {z*-50  color rgb 1}
box{-1,1
  texture{pigment{function{-y/1/2}  color_map{[.0 rgb 0] [1 rgb 1]} }}
  translate <-1.5,1.5,0> }
box{-1,1
  texture{pigment{function{-y/1/(2)}  color_map{[.0 rgb 0] [1 rgb 1]} }}
  translate <1.5,1.5,0>  }
box{-1,1
  texture{pigment{function{y/1/2}  color_map{[.0 rgb 1] [1 rgb 0]} }}
  translate <-1.5,-1.5,0>}
box{-1,1
  texture{pigment{function{y/1/(2)}  color_map{[.0 rgb 1] [1 rgb 0]} }}
  translate <1.5,-1.5,0> }
Subject: Re: Function (optimization?) bug
Date: 25 Dec 2001 06:42:10
Message: <3c286612$1@news.povray.org>
In article <3c27fd29$1@news.povray.org> , "R. Suzuki" <r-s### [at] aistgojp>
wrote:
> Try the below code.
For debugging, use
#declare foo1 = function{"foo1.out" -y/1/(2)}
#declare foo2 = function{"foo2.out" -y/1/2}
and look at the output files.
e-mail: tho### [at] trfde
Date: 25 Dec 2001 20:26:56
Message: <3c292760@news.povray.org>
"Thorsten Froehlich" wrote
> For debugging, use
Followings are the output.  Apparently, foo2 has a problem (while others are
ok).
grow    3
load    SP(0),R2
load    SP(1),R3
load    SP(2),R4
move    R5,R6
move    R0,R5
move    R3,R0
neg     R0,R5
move    R5,R0
move    R6,R5
move    R0,R5
muli    1.000000,R5   # const(1)
loadi   2.000000,R0   # const(2)
div     R0,R5
move    R5,R0
rts
grow    3
load    SP(0),R2
load    SP(1),R3
load    SP(2),R4
move    R5,R6
move    R0,R5
move    R3,R0
neg     R0,R5
move    R5,R0
move    R6,R5
move    R0,R5
muli    2.000000,R5   # const(2)
move    R5,R0
rts
#declare foo3 = function{"foo3.out" y/1/(2)}
grow    3
load    SP(0),R2
load    SP(1),R3
load    SP(2),R4
move    R3,R0
move    R0,R5
div     R0,R5
move    R5,R0
rts
#declare foo4 = function{"foo4.out" y/1/2}
grow    3
load    SP(0),R2
load    SP(1),R3
load    SP(2),R4
move    R3,R0
move    R0,R5
muli    0.500000,R5   # const(3)
move    R5,R0
rts
R. Suzuki
Date: 26 Dec 2001 07:53:09
Message: <3c29c835@news.povray.org>
In article <3c292760@news.povray.org> , "R. Suzuki" <r-s### [at] aistgojp>
> ok).
Yes, internally it is for some not yet investigated reason optimised to
-y/0.5, which in turn is optimised to -y*2.  What it is supposed to do is
not optimise this expression at all...
    Thorsten
Date: 28 Dec 2001 04:07:33
Message: <ihdo2uod1rgij0kpp9a0nl8bdt6q747miq@4ax.com>
On Tue, 25 Dec 2001 12:42:08 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> For debugging, use
Nice feature. Is it supposed to be included in official release or is it only
beta-test feature ? I ask becouse it seems not documented.
ABX
Date: 28 Dec 2001 07:21:08
Message: <3c2c63b3@news.povray.org>
: Nice feature. Is it supposed to be included in official release or is it only
: beta-test feature ?
  It's also nice because you can actually modify that output by hand and then
read it as a function. This allows you doing things that the parser does not
support for one reason or another (eg. recursive calls).
  I don't believe it will be an official feature.
Date: 28 Dec 2001 07:28:21
Message: <avoo2uoro3l4o0teltn03o18gdqvqffvl3@4ax.com>
How ? You mean when I write function{"file.txt" x+y+z} it outputs to file but
for example when I write function{"file.txt"} then this handmade code is readed?
Exactly.
If here is little place for feature request then this is my vote. Also I think
it could be useful for future bug reports (after final 3.5) but I'm affraid it
is not secure feature if it has read as option.
ABX
Date: 28 Dec 2001 08:59:11
Message: <3c2c7aaf@news.povray.org>
: How ? You mean when I write function{"file.txt" x+y+z} it outputs to file but
: for example when I write function{"file.txt"} then this handmade code is readed?
  I don't remember exactly how it was read, but I remember Thorsten talking
about it. (I hope I didn't mispell his name; sorry if I did :) )
Date: 28 Dec 2001 12:24:54
Message: <3c2caae6@news.povray.org>
It won't be included in any final release (there is a compile-time switch to
turn it off).  The reason is that one can "write" programs that reliably
crash and won't run in future version either because the function VM *will*
change.  The output is a more human-readable output of the function VM
instructions to help debugging the function compiler and optimizer.
    Thorsten
Date: 7 Jan 2002 05:48:14
Message: <stti3u8slu0c764ru6qq73vfmcqua3sslp@4ax.com>
On Fri, 28 Dec 2001 18:24:50 +0100, "Thorsten Froehlich" <tho### [at] trfde>
I wonder if there could be addition to documentation with some general rules of
optimizations made by function's parser. For example - is it enough when I write
just:
#macro P(F,G)
function{ x + F*y + z^G }
or should I write:
#macro P(F,G)
function{
  x
  #if (F!=0) + #if (F=1) y #else F*y #end #end
  + #if (G=0) 1#else #if( G=1) z #else z^G #end #end
At this beta time I have unofficial debug stream to check. But what later ?
Considering time of rendering and designing some general systems for isosurfaces
it is important to make as big optimisetion as possible. Not everybody know C to
verify function equation with source of optimizer.
Also I wonder if there could be inline type of function (code of function is
inlined at parsing time instead of calling at render time). So functions could
be unrolled first, and then optimizations applied.
Sorry, I know it is a feature request but I found this thread and this group
best place to add this, when you feel some other group better, send answer there
ABX
