POV-Ray : Newsgroups : povray.beta-test : the lowest pixel getting dimmed Server Time
18 May 2026 19:44:51 EDT (-0400)
  the lowest pixel getting dimmed (Message 13 to 22 of 22)
Subject: Re: the lowest pixel getting dimmed
Date: 23 Dec 2001 08:09:08
Message: <3c25d774@news.povray.org>
"Thorsten Froehlich" wrote:
> It hasn't been a problem for 15 years, so I would
> say it isn't a bug but standard behavior of POV-Ray.
It has been a problem for many, but maybe not big enough a problem for
anyone to make a patch to fix it.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 23 Dec 2001 09:02:47
Message: <3c25e407@news.povray.org>
> This is expected because now the transparency (for the alpha channel) it
> taking into account when doing anti-aliasing.
OK. :-)
Date: 27 Dec 2001 21:56:53
Message: <3c2bdf75$1@news.povray.org>
I disagree. By definition, the camera is supposed to be centered on the
look_at point, but it isn't. For most scenes, the half pixel doesn't matter
very much, but for things which require to-the-pixel accuracy, the current
behavior is *very* annoying. And a lot more scenes require this accuracy
than one would think at first glance. For an example, look no further than
Insert > Scene Templates > Orthographic Scene.
I actually described how to fix it for 3.1g. See my earlier thread, "Camera
is off by half a pixel".
Anders
Date: 28 Dec 2001 12:29:31
Message: <3c2cabfb@news.povray.org>
In article <3c2bdf75$1@news.povray.org> , "Anders K."
If you want it centered, one very simple solution is to add one pixel to the
width and height of the image.
I think orthographic camera scenes are the only place where this may matter
in a very few scenes.  Of course, the above solution will still work fine.
    Thorsten
e-mail: tho### [at] trfde
Date: 28 Dec 2001 15:01:58
Message: <3c2ccfb6$1@news.povray.org>
the
What if I don't want to add one pixel to the width and height of the image?
For example, one of my POV-Ray projects is creating a set of tiles for a 2D
game. There are hundreds of tiles, and they are rendered by a single file as
an animation. I don't want to have to go in manually with an image editor to
remove one row and column from every single image. Moving the camera works,
but then I need to change the amount I move it by every time I change the
size of the images, and I'm making two sizes of tiles (32x32 and 48x48).
matter
That doesn't change the fact that the current behavior is simply incorrect,
and it is very easy to fix. I know you're probably worried about backwards
compatibility, but as you pointed out, it only makes a big difference on a
few scenes, and even on those scenes it would be much better to have the
camera in the right place anyway.
Anders
light_source{6#macro A(B)#declare C=mod(E B);#declare E=(E-C)/B;C#end
#macro B(E)#while(E)#if(A(8)=7)#declare D=D+2.8;#else#if(C<3)cylinder
{0(C=<1 2>).2translate<D+C*A(2)A(4)#else intersection{torus{1 .2}box{
-y 2}rotate<-1 0C+1>*90translate<D+1A(2)*2+1#end-2 13>finish{specular
1}pigment{red 1}}#end#end#end#local D=-8;1}B(445000298)B(519053970)B(
483402386)B(1445571258)B(77778740)B(541684549)B(42677491)B(70)
Date: 28 Dec 2001 17:27:57
Message: <3c2cf1ed@news.povray.org>
Yes, it's not always a useful solution.
Besides, it actually skews the aspect ratio slightly! ;)
> Moving the camera works, but then I need to change the
> amount I move it by every time I change the size of the
I've had the exact same problem every time I create logos, icons, cursors,
web graphics etc. It's rather annoying.
And I don't always use orthographic camera for that by the way.
> is simply incorrect, and it is very easy to fix. I know
> you're probably worried about backwards compatibility,
> on a few scenes, and even on those scenes it would be
> much better to have the camera in the right place anyway.
I agree.
Rune
Date: 28 Dec 2001 23:07:48
Message: <slrna2qgco.hao.ron.parker@fwi.com>
For this was netpbm created.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 29 Dec 2001 10:48:48
Message: <3c2de5e0$1@news.povray.org>
Even if this worked, you shouldn't have to work around incorrect behavior.
However, adding one row and column doesn't even work: it scales everything
by <(w+1)/w, (h+1)/h>. And for camera types other than orthographic, moving
the camera doesn't work either, since objects closer to the camera would get
shifted more than objects farther away. Rotating the camera would skew the
whole image unpredictably. So there is no satisfactory workaround.
Anders
Date: 29 Dec 2001 12:29:50
Message: <3c2dfd8e@news.povray.org>
In article <3c2de5e0$1@news.povray.org> , "Anders K."
Actually, a quick look at the code suggests that your observation may not be
correct (but I never really cared about this part of the code before)...
    Thorsten
Date: 29 Dec 2001 13:17:54
Message: <3c2e08d2@news.povray.org>
everything
moving
get
the
be
> correct [...]...
How so?
Anders
