POV-Ray : Newsgroups : povray.beta-test : Isosurface problem Server Time
18 Dec 2025 19:16:22 EST (-0500)
  Isosurface problem (Message 1 to 10 of 11)
Subject: Isosurface problem
Date: 21 Dec 2001 11:17:33
Message: <3c23609d$1@news.povray.org>
Am I too dummy or is it a bug with pov 3.5 beta 8 and 9 ?
This scene rendered perfectly with pov 3.1g. So, I tried to transpose it to
pov 3.5, but...
Here is a part of the scene :
#declare Pig = function { pigment { wrinkles color_map { [0 rgb 1][1 rgb
0] } } }
#declare Pq =
  isosurface {
    function { y + 0.22 + 0.05*Pig(10*x,10*y,10*z) }
    threshold 0.5
    bounded_by { box { <-0.9, 0, -0.9>, <0.9, 0.5, 0.9> } }
    scale <1, 0.5, 1>
    translate 0.1*y
And the corresponding message error :
  isosurface {
    function { y + 0.22 + 0.05*Pig(10*x,10*y,10*z) } <----ERROR
Parse Error: Expected '.', } found instead
Another attempt with a predefined function :
#declare Pq =
  isosurface {
    function { y + 0.22 + 0.05*f_noise3d(10*x,10*y,10*z) }
    threshold 0.5
    scale <1, 0.5, 1>
    translate 0.1*y
And the resulting message :
  isosurface {
    function { y + 0.22 + 0.05*f_noise3d( <----ERROR
Parse Error: Expected 'operator', ( found instead
A clue : in the scene window, the words "f_noise3d", "f_torus", etc are not
recognized as keywords (povray doesn't give them the keyword colour).
Is it a real problem or am I completely off-topic ?
Rico
Subject: Re: Isosurface problem
Date: 21 Dec 2001 11:24:27
Message: <47o62u8ikfk9f6mq0n775epv4bt3kuc0st@4ax.com>
> pov 3.5, but...
How could it render with pov 3.1g when there wasn't isosurface in 3.1 ?
You are talking probably about MegaPOV but you shouldn't expect exactly the same
behavour becouse megapov was only _unofficial_ set patches
>  isosurface {
The message is right. Pig() returns vector (or color). You should add .gray
operator or change pigment to pattern if you want MEGAPOV's behaviour.
>  isosurface {
Have you included "functions.inc" to this script ?
not completly but almost :-)
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 21 Dec 2001 11:25:48
Message: <3c23628c@news.povray.org>
not
> Rico
Did you try
#include "functions.inc"
-tgq
Date: 21 Dec 2001 11:31:02
Message: <3c2363c6@news.povray.org>
> 0] } } }
> #declare Pq =
>   isosurface {
>     threshold 0.5
>     scale <1, 0.5, 1>
>     translate 0.1*y
>   isosurface {
from 6.7.11.15.1:
When using the identifier, you have to specify which component of the color
vector should be used. To do this, the dot notation is used:
Function(x,y,z).red
Date: 21 Dec 2001 11:47:54
Message: <3c2367ba@news.povray.org>
the same
You are totally right
Uuuuu.... No, I didn't (first time I hear about this file)
Hem. Thanks but I DO am completely off-topic. Sorry for this unnecessary
thread.
Date: 21 Dec 2001 12:13:00
Message: <3c236d9c@news.povray.org>
: The message is right. Pig() returns vector (or color). You should add .gray
: operator or change pigment to pattern if you want MEGAPOV's behaviour.
  The latter is, IMHO, better. Why overburdern the engine with color
calculations when you will not ne using the colors for anything?
Date: 21 Dec 2001 12:39:13
Message: <bpr62ugr9f0hn94dh8arhcv5qvauado608@4ax.com>
Of course in almost all cases pattern is better but sometimes you can't use only
pattern becouse you are interested in gray representation of complicated pigment
with pigment_maps. It seems simpler (but not faster for engine) to use pigment
then rewrite everything with pattern.
ABX
Date: 21 Dec 2001 13:01:42
Message: <3c237906@news.povray.org>
<47o62u8ikfk9f6mq0n775epv4bt3kuc0st@4ax.com>...
AFAIK you should use .hf instead of .gray if you really want what MegaPov
gave you. That's at least my experience and I think I read it here, too.
Marc-Hendrik
Date: 21 Dec 2001 13:06:29
Message: <kcu62u0p4246gdq6vgjaabqp0cjin8ucss@4ax.com>
On Fri, 21 Dec 2001 19:01:36 +0100, "Marc-Hendrik Bremer"
You can read at 6.5.4.2 chapter that hf value = (Red + Green/255)*0.996093. So
it not uses Blue for calculation while iirc megapov's engine returned gray value
which is function of all red, green and blue components.
ABX
Date: 21 Dec 2001 13:16:43
Message: <3c237c8b@news.povray.org>
value
No, you are mistaken.  MegaPOV uses the .hf formula (see isofunc.c function
iso_pigment).
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
