POV-Ray : Newsgroups : povray.beta-test : Isosurface problem Server Time
25 Jul 2026 23:40:09 EDT (-0400)
  Isosurface problem (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Isosurface problem
Date: 21 Dec 2001 11:24:27
Message: <47o62u8ikfk9f6mq0n775epv4bt3kuc0st@4ax.com>
On Fri, 21 Dec 2001 17:17:05 +0100, "Rico" <Eri### [at] wanadoofr> wrote:
> Am I too dummy or is it a bug with pov 3.5 beta 8 and 9 ?
> This scene rendered perfectly with pov 3.1g. So, I tried to transpose it to
> pov 3.5, but...
How could it render with pov 3.1g when there wasn't isosurface in 3.1 ?
You are talking probably about MegaPOV but you shouldn't expect exactly the same
behavour becouse megapov was only _unofficial_ set patches
> And the corresponding message error :
>  isosurface {
>    function { y + 0.22 + 0.05*Pig(10*x,10*y,10*z) } <----ERROR
> Parse Error: Expected '.', } found instead
The message is right. Pig() returns vector (or color). You should add .gray
operator or change pigment to pattern if you want MEGAPOV's behaviour.
> And the resulting message :
>  isosurface {
>    function { y + 0.22 + 0.05*f_noise3d( <----ERROR
> Parse Error: Expected 'operator', ( found instead
Have you included "functions.inc" to this script ?
> Is it a real problem or am I completely off-topic ?
not completly but almost :-)
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)&_((x+y)*.7,z,.1)&_((x+y+2)*.7,z,.1)&_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 21 Dec 2001 11:25:48
Message: <3c23628c@news.povray.org>
> A clue : in the scene window, the words "f_noise3d", "f_torus", etc are
not
> recognized as keywords (povray doesn't give them the keyword colour).
> Rico
Did you try
#include "functions.inc"
-tgq
Date: 21 Dec 2001 11:31:02
Message: <3c2363c6@news.povray.org>
> #declare Pig = function { pigment { wrinkles color_map { [0 rgb 1][1 rgb
> 0] } } }
> #declare Pq =
>   isosurface {
>     threshold 0.5
>     bounded_by { box { <-0.9, 0, -0.9>, <0.9, 0.5, 0.9> } }
>     scale <1, 0.5, 1>
>     translate 0.1*y
>   isosurface {
from 6.7.11.15.1:
When using the identifier, you have to specify which component of the color
vector should be used. To do this, the dot notation is used:
Function(x,y,z).red
Date: 21 Dec 2001 11:47:54
Message: <3c2367ba@news.povray.org>
the same
You are totally right
Uuuuu.... No, I didn't (first time I hear about this file)
Hem. Thanks but I DO am completely off-topic. Sorry for this unnecessary
thread.
Date: 21 Dec 2001 12:13:00
Message: <3c236d9c@news.povray.org>
: The message is right. Pig() returns vector (or color). You should add .gray
: operator or change pigment to pattern if you want MEGAPOV's behaviour.
  The latter is, IMHO, better. Why overburdern the engine with color
calculations when you will not ne using the colors for anything?
Date: 21 Dec 2001 12:39:13
Message: <bpr62ugr9f0hn94dh8arhcv5qvauado608@4ax.com>
Of course in almost all cases pattern is better but sometimes you can't use only
pattern becouse you are interested in gray representation of complicated pigment
with pigment_maps. It seems simpler (but not faster for engine) to use pigment
then rewrite everything with pattern.
ABX
Date: 21 Dec 2001 13:01:42
Message: <3c237906@news.povray.org>
<47o62u8ikfk9f6mq0n775epv4bt3kuc0st@4ax.com>...
AFAIK you should use .hf instead of .gray if you really want what MegaPov
gave you. That's at least my experience and I think I read it here, too.
Marc-Hendrik
Date: 21 Dec 2001 13:06:29
Message: <kcu62u0p4246gdq6vgjaabqp0cjin8ucss@4ax.com>
On Fri, 21 Dec 2001 19:01:36 +0100, "Marc-Hendrik Bremer"
You can read at 6.5.4.2 chapter that hf value = (Red + Green/255)*0.996093. So
it not uses Blue for calculation while iirc megapov's engine returned gray value
which is function of all red, green and blue components.
ABX
Date: 21 Dec 2001 13:16:43
Message: <3c237c8b@news.povray.org>
value
No, you are mistaken.  MegaPOV uses the .hf formula (see isofunc.c function
iso_pigment).
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 21 Dec 2001 13:20:41
Message: <88v62uke303dq9hbl0j20cnib7753jjp5k@4ax.com>
On Fri, 21 Dec 2001 19:16:40 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> MegaPOV uses the .hf formula (see isofunc.c function iso_pigment).
Yes, should I check first, sorry.
ABX
