POV-Ray : Newsgroups : povray.beta-test : Slowdown after starting and stopping during pre-trace Server Time
6 Mar 2026 20:28:48 EST (-0500)
  Slowdown after starting and stopping during pre-trace (Message 1 to 2 of 2)
Subject: Slowdown after starting and stopping during pre-trace
Date: 12 Dec 2001 07:38:50
Message: <3c174fda$1@news.povray.org>
I wrote about this in October and the post got one confirmation, but I've
never seen this on any of the bug lists. But then again I could be
illiterate or just imagining things..
Try doing the following:
1. Start POV-Ray and render the scene below.
2. Write down the render time.
3. Start and stop the scene in pre-trace with alt+g or the toolbar buttons.
Do this a few times.
4. Let POV-Ray render the whole scene.
The trace time increases after a few starts and stops. This has happened
with
most of the betas. With MegaPov 0.7 the same scene works fine. You can get
rid of the problem (or the slowdown is minimal) by lowering the
max_trace_level or by commenting out the reflection or interior. Undo
changes and the trace goes on like granny in a snowdrift.
Ari-Matti
Using: Athlon, 512Mb, POV3.5b8 both compiles, WinXP
PS. Remember to re-start Pov before any final traces to ensure normal trace
times.
//----scene starts----
#version 3.5;
// +h320 +w240
global_settings {
  assumed_gamma 1.0
  max_trace_level 30
   #default {finish {ambient 0}}
   radiosity {}
  location  <-0.4,5.5,-5>
  look_at   <-0.4,1.5, 0>
light_source { <0,0,0> color rgb 1.3 translate <500,300,-150>}
plane {
  y, -0.01
    pigment { color rgb <1.0, 1.0, 1.0> }
difference {
  cone { <0, 0, 0> 1.4 <0, 4.0 ,0> 1.8 }
  cone { <0, 1, 0> 1.1 <0, 4.1 ,0> 1.7 }
    pigment{ rgbt 1 }
    finish {
      reflection { 1 fresnel on}
      conserve_energy
  interior { ior 1.5 }
//eof
Subject: Re: Slowdown after starting and stopping during pre-trace
Date: 12 Dec 2001 14:06:22
Message: <3c17aaae$1@news.povray.org>
confirmed.
Win98 Beta 8 icl
amd 1.4 GHz 512MBRam
the first time povray did it in 31 seconds.
After 5 start-stops during pretrace, povray took 6m17s.
You may look at the number of traced rays - it was multiplied by
factor 7.
