POV-Ray : Newsgroups : povray.beta-test : Workaround for function problems in beta 8 without scene file modification Server Time
27 Jul 2026 03:00:25 EDT (-0400)
  Workaround for function problems in beta 8 without scene file modification (Message 11 to 20 of 20)
Subject: Re: Workaround for function problems in beta 8 without scene file modification
Date: 8 Dec 2001 03:23:25
Message: <Xns9171227C5B3DBCoridonHenshaw@204.213.191.226>
"bob h" <omn### [at] charternet> wrote in news:3c11ca0a$1@news.povray.org:
> So... has not stopped from crashing again.  Maybe someone has ideas on
> another temporary fix.
Just manually include the workaround include in every scene file which 1)
uses isosurfaces and 2) you plan to work on using beta 8.  The workaround
works; include_header is broken for at least some people.
Date: 8 Dec 2001 05:04:53
Message: <3c11e5c5@news.povray.org>
In article <Xns### [at] 204213191226> ,
Something cannot break for just a few people.  Programming is no magic.
    Thorsten
e-mail: tho### [at] trfde
Date: 8 Dec 2001 05:10:54
Message: <3c11e72e@news.povray.org>
In article <3c11ca0a$1@news.povray.org> , "bob h" <omn### [at] charternet>
wrote:
> I spoke too soon, the current.ini returned after closing POV-Ray and going
> back to it shortly afterward.  Checking pvengine.ini shows that did not
> change though so I don't know how I kept the file from returning only
> momentarily before.
If you put the option on the command line (+hi switch) rather than in
povray.ini, does it work for you?
    Thorsten
Date: 8 Dec 2001 13:10:34
Message: <3c12579a@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c11e72e@news.povray.org...
It does indeed.  I also noticed that when I could get a render to be done at
least one time through before that the function wasn't being applied from
the looks of the isosurface.  With the +hiBeta8fix.inc working I see what
should be rendered.
Thanks for coming up with that answer.
text{ttf"arial","bob h",.1,0pigment{rgb 9}translate<-1,-.2,3>}
Date: 8 Dec 2001 16:58:29
Message: <3c128d05$1@news.povray.org>
This is probably a stupid question, but why does POV only support one
include header?
Date: 8 Dec 2001 19:09:15
Message: <3c12abab@news.povray.org>
In article <3c128d05$1@news.povray.org> , "Anders K." <and### [at] f2scom>
> include header?
Because it was easy to implement.
    Thorsten
Date: 8 Dec 2001 21:45:02
Message: <Xns9171DD41EA86CoridonHenshaw@204.213.191.226>
news:3c11e72e@news.povray.org:
Works here.
"Thorsten Froehlich" <tho### [at] trfde> wrote in news:3c11e5c5
@news.povray.org:
It's certainly possible for bugs to manifest themselves only on specific
system configurations, which would give the impression that things are
broken for some beta testers but not others.
Date: 9 Dec 2001 08:57:13
Message: <3c136db9@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
:> This is probably a stupid question, but why does POV only support one
:> include header?
: Because it was easy to implement.
  And there isn't really need to support more. Why? Because you can put
all the includes you want inside that one include header.
Date: 12 Dec 2001 20:20:34
Message: <3c1801ee.6452989@localhost>
On 7 Dec 2001 18:24:10 -0500, che### [at] sympaticoca (Coridon Henshaw)
wrote:
>Warp <war### [at] tagpovrayorg> wrote in news:3c11413e@news.povray.org:
>>   It doesn't crash here (when I use the workaround).
>Crashes here if I use Include_Header in povray.ini.  Further testing
>reveals that beta 8 ignores the Include_Header directive.  Pov won't parse
>any file referenced there nor will it issue an error message if
>include_header points to a non-existant file.
>Bob H's test scene works fine if I #include the workaround header.
>Tests conducted on both my WinME and Win2K boxes.
I can confirm this.  The include_header directive did not fix
the problem but #including workaround.ini in each pov file does
fix the problem.  Tested on Windows ME.  Will try to test on
Windows 2000 tomorrow.
Pete
Subject: Re: Workaround function problems in beta 8 = +hiFilename command switch
Date: 12 Dec 2001 23:56:24
Message: <3c1834f8$1@news.povray.org>
As Thorsten suggested, if you put +hiWorkaround.inc (or whatever the file
name you chose to make) into the command line POV-Ray doesn't crash anymore.
Just wanted to point that out again in case anyone reading this has missed
that.
<Pet### [at] nymaliasnetalmost> wrote in message
news:3c1801ee.6452989@localhost...
parse
