POV-Ray : Newsgroups : povray.beta-test : Keep Single Instance (always does, no matter setting) Server Time
14 Jun 2026 07:10:55 EDT (-0400)
  Keep Single Instance (always does, no matter setting) (Message 1 to 10 of 10)
Subject: Keep Single Instance (always does, no matter setting)
Date: 3 Dec 2001 00:07:13
Message: <3c0b0881$1@news.povray.org>
3.5.beta.8.icl.win32, P3, WinXP
This was okay before now, if I remember right.  Now POV won't run multiple
instances.  At least not while rendering (tried Pause to check that anyway,
can't stop a current render).
text{ttf"arial","bob h",.1,0pigment{rgb 9}translate<-1,-.2,3>}
Subject: Re: Keep Single Instance (always does, no matter setting)
Date: 3 Dec 2001 04:28:16
Message: <3c0b45b0@news.povray.org>
"bob h" <omn### [at] charternet> wrote in message
news:3c0b0881$1@news.povray.org...
anyway,
Same as:
http://news.povray.org/3c094eb8$1@news.povray.org
> I think it works too well. Keep single instance is turned off but I can't
> start a new instance of Pov either by double-clicking a file, the Pov
> short-cut or even the pvengine.exe. Every time the currently runnig pops
> up.
Date: 3 Dec 2001 08:41:21
Message: <u10n0u8e2v6975ngnaj3qao1knrjb0ftj5@4ax.com>
I can confrim. Moreover I can't start second compiler version. I have compassion
to IRTC competitors.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 3 Dec 2001 09:57:32
Message: <3c0b92dc@news.povray.org>
"Ari-Matti Leppanen" <ari### [at] tutfi> wrote in message
news:3c0b45b0@news.povray.org...
> Same as:
can't
> > up.
Seen that, yes, missed your reply to it.  Considered that a different bug
report before.
Date: 3 Dec 2001 16:34:16
Message: <KFQFOBAC2+C8Ew5x@econym.demon.co.uk>
Can't start 3.5 at all if MegaPOV and/or 3.1 are running (all three have
"keep single instance" switched off).
Mike Williams
Gentleman of Leisure
Date: 17 Jan 2002 02:24:53
Message: <Cmb32DAi+dR8EwSX@econym.demon.co.uk>
Would I be right in thinking that this is fully fixed now? In beta 9
there was a partial fix (if you switched it off and on again it worked)
but beta 10 seems to work correctly straight out of the box for me. I
can't see anything in changes.txt that suggests that it was addressed.
Mike Williams
Date: 17 Jan 2002 03:31:05
Message: <ir2d4u0qjsm45080vbgohhjmuge9ojm4tp@4ax.com>
On Wed, 16 Jan 2002 20:16:34 +0000, Mike Williams <mik### [at] nospamplease> wrote:
> I can't see anything in changes.txt that suggests that it was addressed.
Change 1336 on 2002/01/13 by chrisc@lilliput
  Fix problem with 'Keep Single Instance' menu item starting in wrong state.
ABX
Date: 17 Jan 2002 23:57:43
Message: <WfXi4AATq0R8EwDK@econym.demon.co.uk>
The changes.txt that I got only goes up to 1330.
Mike Williams
Date: 18 Jan 2002 02:51:12
Message: <dpkf4uc81q3lsn2nju3ii266f2v5a85j4t@4ax.com>
On Thu, 17 Jan 2002 22:05:07 +0000, Mike Williams <mik### [at] nospamplease> wrote:
Are you sure you are reading proper file ?
1330 is last change in revision.txt which contains renderer changes.
Quoted 1336 is last change in changes.txt which contains platform specific
changes.
ABX
Date: 18 Jan 2002 17:02:40
Message: <+8bYwTAuGHS8EwsB@econym.demon.co.uk>
>changes.
Oh, right. I was reading the file called "changes.txt" that's on the
Windows beta web page. Where "You can read a list of <changes between
beta.1 and beta.10>".
Mike Williams
