POV-Ray : Newsgroups : povray.beta-test : Problems starting Beta8 from Command Line Server Time
31 Mar 2026 11:43:59 EDT (-0400)
  Problems starting Beta8 from Command Line (Message 1 to 3 of 3)
Subject: Problems starting Beta8 from Command Line
Date: 2 Dec 2001 18:38:15
Message: <3c0abb67@news.povray.org>
I've noticed something strange when starting POV-Ray v3.5 (beta.8.icl.win32)
from the command line.
A simple command such as:
>pvengine.exe F:\test.ini
should start POV-Ray and begin rendering the test.ini file.
If POV-Ray is NOT running this does as expected, and renders the file.
However if is ALREADY running (but not rendering) then it doesn't start
rendering the file as it should (although it does become the active window).
In prior versions (v3.1 and v3.5.beta.1-7)  the file would be rendered
regardless of whether POV-Ray was already running or not.
The problem also occurs when starting POV-Ray using a Visual Basic Shell()
command. (I specifically noticed it when experimenting with my 'Forester'
program).
Cheers - and thanks for a fantastic program!
PC: Pentium III 500MHz 384Mb SDRAM Win98SE
Forester Website: www.dartnall.co.uk
Subject: Re: Problems starting Beta8 from Command Line
Date: 3 Dec 2001 04:25:40
Message: <3c0b4514$1@news.povray.org>
"Stephen Dartnall" <ste### [at] dartnallcouk> wrote in message
news:3c0abb67@news.povray.org...
> Hi,
(beta.8.icl.win32)
Same as:
"Pabs" <NOp### [at] NOzSiPpAMto> wrote in message
news:3C0### [at] NOzSiPpAMto...
> 1. The keep single instance option works, but, according to the docs,
> when double-clicking a file in explorer that file should be opened in
> the instance that is already running. currently the running instance is
> just brought into the foreground. This has been around since 3.1 & I
> think 3.0.
Date: 3 Dec 2001 13:03:25
Message: <qQadrHArX7C8EwM5@econym.demon.co.uk>
Wasn't it Stephen Dartnall who wrote:
>Hi,
>program).
It sounds like it might possibly be related to one of the points raised
in
2 Win GUI bugs + nitpick
http://news.povray.org/3C073446.3020104@NOzSiPpA.Mto
Mike Williams
Gentleman of Leisure
