POV-Ray : Newsgroups : povray.beta-test : IsoCacti.pov Server Time
6 Mar 2026 23:23:07 EST (-0500)
  IsoCacti.pov (Message 1 to 10 of 14)
Subject: IsoCacti.pov
Date: 1 Dec 2001 06:47:56
Message: <3c08c36c$1@news.povray.org>
Athlon, 512 Mb ram, Win ME, beta 8(both compiles)
IsoCacti.pov in advanced dir gives dozens of max_gradient found
was 0.000 warnings for line 73.
Is this a bug or a case of "bad" functions?
-Jide
Subject: Re: IsoCacti.pov
Date: 1 Dec 2001 09:03:05
Message: <1lhKWBAHJOC8Ewd3@econym.demon.co.uk>
I think it's a consequence of this change (from changes.txt)
Change 1239 on 2001/11/02 by thorsten@host27
  Some more isosurface changes to re-enable 'evaluate', which is
   now only responsible for the 'dynamic max_gradient' method.
  The found maximum gradient will always be printed based on
   certain rules. It is no longer necessary to use 'evaluate' only
   to see the found maximum gradient!
There are 754 isosurfaces in the scene (the ground, 3 cacti and 750
small stones) and an evaluate warning is displayed for each one of them.
(It's a good job the "too many evaluates" bug got fixed).
The details of the evaluate warnings are not correct. Many of them
suggest that the max_gradient should be changed to 0.000, but that's not
a legal value.
Mike Williams
Gentleman of Leisure
Date: 1 Dec 2001 09:25:28
Message: <3c08e858$1@news.povray.org>
1lh### [at] econymdemoncouk...
> a legal value.
Two additional problems :
- giving a max_gradient doesn't remove the warnings
- putting -GW on the command line doesn't remove the warnings either (-GA
does remove them and the statistics)
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 1 Dec 2001 09:57:04
Message: <3C08EFB0.B70ADFAE@gmx.de>
Yes, the estimated max_gradient is now always displayed in a warning if it
differs too much from the given one.  The warning displayed with dynamic
max_gradient (evaluate) is the same although this is misleading and will
probably be changed.
Date: 1 Dec 2001 10:10:24
Message: <3c08f2e0@news.povray.org>
In article <3c08e858$1@news.povray.org> , "Gilles Tran" <tra### [at] inapginrafr>
I never used text streams so I can't really tell you how those work, but I
can tell you that it is easily possible to turn off warnings and only
warnings.  The information is in the appropriate place in the documentation.
    Thorsten
e-mail: tho### [at] trfde
Date: 1 Dec 2001 11:01:52
Message: <3c08fef0@news.povray.org>
3c08f2e0@news.povray.org...
documentation.
Yes, that's exactly what I'm saying (see 5.2.5.2  Console Text Output)
-GW turns off the warnings, but not the new isosurface warnings.
Right now, the only workaround to turn off the iso warnings is to use -GA,
which removes almost all the text output.
G.
- Posters
>     Thorsten
Date: 1 Dec 2001 11:25:30
Message: <3c09047a@news.povray.org>
In article <3c08fef0@news.povray.org> , "Gilles Tran" <tra### [at] inapginrafr>
It is in section 5.2.5, maybe you should read the whole section.  All you do
right now is hide the warnings, but you can really turn them off!
    Thorsten
Date: 1 Dec 2001 15:25:25
Message: <3c093cb5@news.povray.org>
But you agree that there's a bug of some sort: I have too a scene with
several hundred isos and, once POV-Ray has finshed to trace, I have to wait
a minute for all those warnings saying that the maximum gradient found is
0.000.
Jonathan.
"Thorsten Froehlich" <tho### [at] trfde> ha scritto nel messaggio
news:3c09047a@news.povray.org...
use -GA,
do
>     Thorsten
Date: 1 Dec 2001 15:52:08
Message: <3c0942f8@news.povray.org>
In article <3c093cb5@news.povray.org> , "JRG" <jrg### [at] hotmailcom> wrote:
> 0.000.
It does this only if the gradient found was really zero, which can i.e. be
the case if there was no intersection.  I will adjust the warning message to
ignore such cases, yet.
That Gilles can't turn off the warning with -GW is also not correct,
however, there is a much better workaround than - GA in section 5.2.5.4 of
the documentation, which explains the warning level option.  Hopefully
Gilles has found it by now...
    Thorsten
Date: 1 Dec 2001 16:27:13
Message: <3c094b31@news.povray.org>
I personally got rid of them with +wl0.
