POV-Ray : Newsgroups : povray.beta-test : Isosurface : 2 bugs Server Time
13 Oct 2025 06:45:50 EDT (-0400)
  Isosurface : 2 bugs (Message 1 to 10 of 10)
Subject: Isosurface : 2 bugs
Date: 30 Nov 2001 20:09:18
Message: <3c082dbe@news.povray.org>
1. '|' and '&'
 According to POV-Help 6.5.4.4.1&2, the operator '|' means merge
 and '&' means intersection.
 But these operators don't work properly on beta 8.
 For example, following isosurface is not the intersection
 of two spheres.
   isosurface{
     function { f_sphere(x,y,z,1) & f_sphere(x+0.5,y,z,1)}
 These were ok on beta 7.
2. 'int()'
 The function 'int()' does not work in isosurface.
 Try the following isosurface.
   isosurface{
      function { int(0.5)}
      threshold 0.5
 POV-Ray crashes on my PC.
 POV-Ray for Windows 3.5 beta 8, Windows Me, Celeron 600MHz
R. Suzuki
Subject: Re: Isosurface : 2 bugs
Date: 1 Dec 2001 03:58:47
Message: <hyq$jDAqdJC8EwuB@econym.demon.co.uk>
Wasn't it R. Suzuki who wrote:
>1. '|' and '&'
> of two spheres.
>   isosurface{
>2. 'int()'
>   isosurface{
>      threshold 0.5
I confirm these, but will entertain suggestions that #1 might be
mathematically correct as long as the intersection and merge of
isosurfaces now get documented this way round.
Mike Williams
Gentleman of Leisure
Date: 1 Dec 2001 07:09:12
Message: <3c08c868@news.povray.org>
In article <3c082dbe@news.povray.org> , "R. Suzuki" <r-s### [at] aistgojp>
wrote:
> 1. '|' and '&'
>  of two spheres.
The operators work as designed, the documentation hasn't been updated.  The
operators don't mean merge or interesection.  Unse min and max.  Or if there
is demand, I could add a difference and an intersection function (with two
or more arguments!).
    Thorsten
e-mail: tho### [at] trfde
Date: 1 Dec 2001 12:24:48
Message: <3c091260@news.povray.org>
The
there
I used these operators as geometric operators in the isosurface patch
because it seems to be common in this field.
See http://wwwcis.k.hosei.ac.jp/~F-rep/HF_oper.html
If those are not allowed, how about "iso_union(A, B, C, D, ...)" and
"iso_intersection(A, B, C, D, ...)".
R. Suzuki
Date: 1 Dec 2001 12:59:55
Message: <3c091a9b$1@news.povray.org>
In article <3c091260@news.povray.org> , "R. Suzuki" <r-s### [at] aistgojp>
I know, but unfortunately POV-Ray defines the same operators to work like
logic in the parser, and as functions can be used anywhere and for
consistency they really have to work as in the parser.
I will look into adding union and intersection (no new keywords).  BTW, do
you by any chance know how (if possible at all) to implement a 'difference'?
the link you provided suggests it is possible.  SO if it would be a really
simple implementation I might be able to add it as well...
    Thorsten
Date: 1 Dec 2001 13:26:38
Message: <3C0920E9.3D2EE8D2@gmx.de>
difference is simply intersection with the inverse (negative in isosurface
if you have threshold 0)
Anyway i think other things are more important. ;-)
Date: 1 Dec 2001 13:53:12
Message: <3c092718@news.povray.org>
"Thorsten Froehlich"  wrote:
>BTW, do  you by any chance know how (if possible at all) to
>implement a 'difference'?  the link you provided suggests it is
>possible.  SO if it would be a really simple implementation I might
This is really simple as Christoph pointed out.
See POV Help 3.4.4.5.
(The operators in these documents should be also fixed.)
R. Suzuki.
Date: 2 Dec 2001 04:10:06
Message: <3c09efee@news.povray.org>
In MATLAB, which is one of the most commonly used mathematical
programing language, there are UNION(A,B) function and
INTERSECT(A,B) function, but the meaning is totally different.
So, those function names will confuse some people.
R. Suzuki
Date: 2 Dec 2001 07:30:15
Message: <3c0a1ed7$1@news.povray.org>
In article <3c09efee@news.povray.org> , "R. Suzuki" <r-s### [at] aistgojp>
Maybe I should just leave it as is and only create a min and max function
that take more than two arguments.  It would still keep the syntax as simple
as it was with & and | and avoid misunderstandings.
I will also fix the & and | using min/max so they behave like true boolean
operators...
    Thorsten
Date: 3 Dec 2001 04:44:16
Message: <3c0b4970@news.povray.org>
>only create a min and max function that take more than two
>arguments.
This would be nice.
R. Suzuki
