POV-Ray : Newsgroups : povray.beta-test : Colour clipping. Server Time
18 Feb 2026 14:47:12 EST (-0500)
  Colour clipping. (Message 1 to 10 of 13)
Subject: Colour clipping.
Date: 30 Nov 2001 08:02:45
Message: <3c078375$1@news.povray.org>
I've discussed colour clipping in the other groups before but never really
got a clear answer on what I really wanted to know.
When a colour is clipped, is it clipped by povray when it writes the output
file or somewhere else.  If it is clipped by POV-Ray, is it possible to have
POV clip it proportionally so that rgb<100,50,0> would get clipped to
<1,.5,0> (orange) and not to <1,1,0> (yellow).  I don't know if this is
simple or if it is out of POV's control.  I like using bright colours for
light sources sometimes and this limits that technique to using pure colours
(i.e., only 1s and 0s)
-tgq
Subject: Re: Colour clipping.
Date: 30 Nov 2001 08:26:47
Message: <3c078917@news.povray.org>
In article <3c078375$1@news.povray.org> , "Trevor Quayle"
No, POV-Ray writes the image pixel by pixel and line by line to file so no
data is lost in a ten day render when your computer crashes in the mean time
and for memory conservation problems.  In order to do what you suggest,
POV-Ray would need to store the whole image in memory in the unclipped form.
That requires at least 12 bytes per pixel (single precision floating-point
rgb values), so rendering at i.e. 1280*1024 would require 15 MB alone!
Nearly all your problems can be avoided by more carefully tweaking the light
sources in your scene with "sane" values.  For special effects with very
strong lights I would suggest to use light_groups because this way you can
reduce the effect those lights have on the scene.
> I've discussed color clipping in the other groups before but never really
This group is for discussing beta bug reports because the time is past for
feature requests and you are asked to keep the off topic chatter down to an
absolute minimum.  Not getting a response in another group is no good
justification for posting here.  Please read about the purpose of this group
in the welcome message (the first message in this group, dated Sept 4th) or
see the web archive of this group:
<http://news.povray.org/povray.beta-test/17912/>
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 30 Nov 2001 09:19:07
Message: <3c07955b@news.povray.org>
"Thorsten Froehlich" wrote:
> In order to do what you suggest, POV-Ray would need to
I understood his request as proportional clipping at a per-pixel basis. I
imagine it wouldn't require any additional memory at all and that it would
be pretty simple to implement. It's still a feature request though...
Also, if it is ever implemented it should definitely be optional (controlled
from the global_settings block). Even better than on/off would be a float
that could be from 0 to 1, like what metallic is for highlights.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Date: 30 Nov 2001 10:00:49
Message: <3c079f21@news.povray.org>
time
form.
1) This is not what I meant as Rune has pointed out.  The pixel obviously
gets clipped when POV writes it. My intention was why not clip it
proportional to itself rather than absolutely.
an
group
or
2) It is only a feature request and if it is the intended function. I can't
find anywhere in the docs where it is stated that this is the case nor can I
find a disclaimer stating that using values >1 could lead to unexpected
results.  If not a bug-report, than at least it should be clarified in the
docs.
3) I wouldn't have posted here if I didn't think it was justified, I have
seen a lot of other off-topic chatter here that didn't garner the same
response.  I have been testing 3.5 beta since it came out and have tried to
adhere to the posting guidelines for this group. My original query in the
other groups was to find out if it was intended or not so I wouldn't be
posting here without reason.
-tgq
Date: 30 Nov 2001 11:04:04
Message: <3c07adf4@news.povray.org>
In article <3c079f21@news.povray.org> , "Trevor Quayle"
> docs.
Well, as it worked this way every since there has been POV-Ray, how can it
be a bug?  Simply trying it out in 3.1 or earlier could have answered the
question.  And you surely have used 3.1 before so you know it worked its way
there.
Apart from that, nowhere in your original post you suggest it is a bug, and
no matter how often I read it, even between the lines I can't find a bug
report in there.  Your post doesn't sound very "polished" either, which it
should have been if you had seriously discussed it before elsewhere.  Of
course explaining complex ideas can be difficult, but trying to think about
them more would be a good idea.
I see.  Indeed, this would not require to store the whole image.  However,
as it hasn't been needed in 15 years and I don't remember a patch for it or
any suggestion for such a patch.  I really wonder why it would be an feature
so important it has to be added to 3.5 (so to post here), if it would be a
worthwhile feature in the first place is yet another question, but I don't
want to get into a discussion about new features at all...
> response.
Few people created off-topic threads, most of the time it developed
throughout a thread.  Saying you post here because "I've discussed color
clipping in the other groups before but never really got a clear answer on
what I really wanted to know" surely doesn't sound a justification to me,
only like a way to force some answer, which you got.
As for my reminder, it was not personal and wasn't written this way either,
it was a reminder about the rules we have set up in these groups and try to
hold up.  That occasionally this doesn't work is hardly a justification for
ignoring the rules :-)
    Thorsten
e-mail: tho### [at] trfde
Date: 30 Nov 2001 11:37:58
Message: <3c07b5e6@news.povray.org>
> been POV-Ray, how can it be a bug?
Why do some people keep saying that? Just because something worked the same
way in POV-Ray 3.1, it doesn't mean it can't be a bug. In fact POV-Ray 3.1
has some quite serious bugs, such as the normal bug.
> However, as it hasn't been needed in 15 years
That's not for any individual to say. Maybe *you* didn't need it...
> I really wonder why it would be an feature so important
Well, here I agree. It's not that important... But he may have a point that
it maybe should be mentioned in the docs.
Rune
Date: 30 Nov 2001 12:08:44
Message: <3c07bd1c@news.povray.org>
In article <3c07b5e6@news.povray.org> , "Rune" <run### [at] mobilixnetdk>
I said it works this way "every since there has been POV-Ray", ***not***
that it always worked this way only in POV-Ray 3.1.  How about actually
reading what I say before picking on it???
Please don't take half of my sentence away and then put words in my mouth.
I said "However, as it hasn't been needed in 15 years and I don't remember a
patch for it or any suggestion for such a patch." and it is quite obvious
what I mean if you read the sentence and maybe the whole paragraph to the
*end*.
Actually, I think the docs mention that the colors are clipped somewhere.  I
have to admit I don't know where from memory and I don't have time to look
right now...
    Thorsten
Date: 30 Nov 2001 12:21:25
Message: <3c07c015$1@news.povray.org>
I
> right now...
As I stated, I searched and cannot find it.  I realized what was going on by
accident from some previous thread in one of the other groups.
-tgq
Date: 30 Nov 2001 12:29:47
Message: <3c07c20b@news.povray.org>
In article <3c07c015$1@news.povray.org> , "Trevor Quayle"
> I
>> right now...
I think if it really isn't anywhere in the docs, it should be added.
    Thorsten
Date: 30 Nov 2001 12:36:50
Message: <3c07c3b2@news.povray.org>
> been POV-Ray", ***not*** that it always worked
Not all users have versions of POV-Ray installed prior to version 3.1. And
you said "Simply trying it out in 3.1 ***or*** earlier could have answered
the question." I find that you implied that trying it out in POV-Ray 3.1
would be enough to find out if it was a bug. Demanding the user to test it
in earlier versions than that would be unfair anyway IMO.
I find the rest of the sentence irrelevant. I think most POV-Ray users are
not active in the POV-Ray society at all. But I agree that the fact that
there hasn't been a patch or much discussion indicates that the need has not
been particularly strong among most users.
Rune
