POV-Ray : Newsgroups : povray.beta-test : Marble + Turbulence + Isosurface ( bug ? ) Server Time
17 May 2026 08:38:56 EDT (-0400)
  Marble + Turbulence + Isosurface ( bug ? ) (Message 1 to 8 of 8)
Subject: Marble + Turbulence + Isosurface ( bug ? )
Date: 29 Nov 2001 10:51:18
Message: <3c065976@news.povray.org>
Make I something wrong or is this bug?
Rendered picture in beta-test.binaries.
#version 3.5;
global_settings {
  assumed_gamma 1.5
  location  <-1.0, 3.5, -4.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {
  <1, 7.5, -8>
  color rgb <1, 1, 1>
plane {
  y, -1.5
      marble
      color_map {
        [0.0  color rgb < 1,   1,   1   > ]
        [0.33 color rgb < 0,   0.5, 1   > ]
        [0.67 color rgb < 0,   1,   0.5 > ]
        [1.0  color rgb < 1,   1,   1   > ]
      turbulence 0.3
      scale 4
    finish { ambient 0.5 specular 0.6 }
#declare f3 = function {
                  pigment{
                     crackle
                     turbulence 0
                     color_map { [0 rgb 1] [1 rgb 0] }
isosurface {
 function { abs( - z - f3(x,y,z).gray*0.0 ) - 0.01 }
 // see also
 // function { z }
 // function { abs(y)-0.01 }
 threshold 0
 max_gradient 2
 contained_by {box {<-1.2,-1.2,-1.2>, < 1.2, 1.2, 1.2>}}
          pigment { color rgbt <1,0,0,0.8> }
   finish {ambient 1 diffuse 0.6}
Gabriel
Kon### [at] GGnatowskide
Subject: Re: Marble + Turbulence + Isosurface ( bug ? )
Date: 29 Nov 2001 11:31:23
Message: <3c0662db@news.povray.org>
In article <3c065976@news.povray.org> , "Gabriel" <Kon### [at] GGnatowskide>
It would help if you would explain where to look for "something wrong" in
the picture and you expect it to look.
    Thorsten
PS: In the future, please post images in JPEG (preferred) or PNG format.
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 29 Nov 2001 14:12:54
Message: <3c0688b6@news.povray.org>
There is really something strange.
- f3(x,y,z).gray*0.0 is supposed to be always 0 and therefore should not
effect the isosurface at all, no? But it does influence the isosurface.
In addition (and perhaps the problem the original author meant), the
turbulated marble plane shows up as using no turbulence in the pigment
statement while seen through the isosurface (container?). Lowering the
accuracy-value seems not to have any effect 8tryed 0.0001. But by removing
the turbulence in the marble pigment, everything renders as expected.
Perhaps it's related to the marble + turbulence bug reported as fixed in the
next beta?
Marc-Hendrik
PII 450, 128 MB, Win 98, Pov 3.5 beta 7
Thorsten Froehlich schrieb in Nachricht <3c0662db@news.povray.org>...
>    Thorsten
>Thorsten Froehlich
Date: 29 Nov 2001 14:30:25
Message: <3c068cd1@news.povray.org>
In article <3c0688b6@news.povray.org> , "Marc-Hendrik Bremer"
> next beta?
Yes, but I don't understand what the isosurface has to do with marble.  As
far as I can tell the isosurface doesn't use marbel, so where am I supposed
to look for a problem?  In the marble plane or the isosurface?  If it is in
the marble plane, why is there an isosurface in the scene?
See, I need to know what effect is supposed to be there and what is wrong
with the current output in order to even know what I am supposed to fix, if
anything at all...
    Thorsten
Thorsten Froehlich
Date: 29 Nov 2001 14:35:47
Message: <3c068e13$1@news.povray.org>
Wait a minute (I should have, before I posted my last message, but you will
be used to this already :o})
While it's still strange what happens when f3*0 is involved, I could bring
up the turbulated marble by lowering the accuracy-value even more.
Probably the f3*0-problem is also resolvable by really high settings for
max_gradient and a sufficent small container. It's strange anyway, cause one
would not suspect accuracy problems when multiplying by zero, nor should
this increase the max_gradients.
Marc-Hendrik
Marc-Hendrik Bremer schrieb in Nachricht <3c0688b6@news.povray.org>...
the
>next beta?
>Marc-Hendrik
Date: 29 Nov 2001 15:12:02
Message: <3c069692@news.povray.org>
Thorsten Froehlich schrieb in Nachricht <3c068cd1@news.povray.org>...
the
>> next beta?
The Iso on it's own has nothing to do wth the marble. It's just that looking
through the translucent Iso shows the turbulated pattern on the plane as if
it's not turbulated. Checker or gradient y does not behave that way.
In addition, the container-object is visible in that it shows the
unturbulated marble, too, but in a blocky way.
The first problem is partly resolveable by a low accuracy and removing the
f3(x,y,z)*0-part. But even with very low settings, you don't get the "real"
turbulated marble-pattern, but something which seems to be sized down.
The second one (visible container) keeps poping up but with max_gradient
20000 and a smaler Container in the z-direction, it begins to show
someturbulence, too.
>anything at all...
Yep, that's clear. I thought, I wrote something sufficient in my first post.
Obviously not. Hope this one is better. I, too, just try to find out what
happens.
Marc-Hendrik
Date: 29 Nov 2001 16:48:02
Message: <3c06ad12@news.povray.org>
In article <3c069692@news.povray.org> , "Marc-Hendrik Bremer"
Ah, I think I know what you are up too:  The idea is that when looking
through the isosurface the pattern looks wrong?
If so, lets indeed wait for the next beta, as I am not sure what was fixed
regarding marble...
    Thorsten
Thorsten Froehlich
Date: 29 Nov 2001 17:01:37
Message: <3c06b041@news.povray.org>
Thorsten Froehlich schrieb in Nachricht <3c06ad12@news.povray.org>...
Yes, that's my idea. I don't know if this is what the original poster had in
mind, though.
>regarding marble...
Ok, it's not that long anyway :-)
Marc-Hendrik
