POV-Ray : Newsgroups : povray.beta-test : Splash Screen Server Time
18 May 2026 21:49:04 EDT (-0400)
  Splash Screen (Message 11 to 20 of 31)
Subject: Re: Splash Screen
Date: 24 Nov 2001 11:16:55
Message: <slrn9vvhvp.do9.ron.parker@fwi.com>
On 24 Nov 2001 05:41:06 -0500, Warp wrote:
> Coridon Henshaw <che### [at] sympaticoca> wrote:
>: Your best bet here is probably to wait until the 3.5 sources release and
>: then compile a Win32 command-line version using a cut-down DOS front end.
>: The DOS front end doesn't throw up a splash screen so you can run
>: background renders--completely within the terms of povlegal--without
>: getting splashed.
>   Just be sure to not to distribute this version.
It can be distributed, so long as it meets all the rules set out in POVLegal.
That means it has to display the copyright notice, of course, but it doesn't
have to bring up a splash screen as it would be based on a (nonexistent)
version that doesn't actually bring up a splash screen.
Of course, the Unix version can be redirected to /dev/null and all copyright
text gets sent to the bit bucket; I don't know of any way to prevent that
sort of abuse and still provide a command-line version of POV.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 24 Nov 2001 11:29:34
Message: <3bffcaee@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Of course, the Unix version can be redirected to /dev/null and all copyright
: text gets sent to the bit bucket; I don't know of any way to prevent that
: sort of abuse and still provide a command-line version of POV.
  I think this falls into the category "the user is granted the
privilege to modify and compile the source code for their own personal
use in any fashion they see fit."
Date: 24 Nov 2001 11:47:46
Message: <slrn9vvjpk.dpe.ron.parker@fwi.com>
What if someone distributes a script that invokes the official POV in such
a way as to conceal the copyright notice?  I think that's sorta covered under
the clauses about linking, but I wonder whether there's a problem there.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 24 Nov 2001 12:48:26
Message: <3bffdd6a@news.povray.org>
In article <slr### [at] fwicom> , Ron Parker
All this would be covered by the "Any attempt to obscure the fact that the
sections (the commercial and unofficial sections) in povlegal.doc.  So such
a script being distributed together with POV-Ray in form of an unofficial
version or commercial distribution would not be allowed.  Of course only
distributing the script would be legal as the user can do with POV-Ray what
he wants, even obscure the fact that he is running POV-Ray to himself, which
shouldn't be a problem...
    Thorsten
e-mail: tho### [at] trfde
Date: 24 Nov 2001 13:31:34
Message: <Xns91638998AE1C7CQ@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3bff7942@news.povray.org:
>: and then compile a Win32 command-line version using a cut-down DOS
>: front end.  The DOS front end doesn't throw up a splash screen so you
>: can run background renders--completely within the terms of
>: povlegal--without getting splashed.
The result of following my instructions is to port Pov to the Win32 console
platform.  Win32 console apps cannot generate splash screens.  The only
requirements in Povlegal for presenting the credits in text-based ports is
that the credits screen is left intact.  Unless you are arguing that it is
illegal to port Povray to any command-line platform, I see no reason that a
Win32 console port would be illegal.
Date: 24 Nov 2001 16:34:20
Message: <3c00125c$1@news.povray.org>
console
a
just get it to echo a the legally required oompf to the console as soon as
it starts
PGP Public Key
Date: 24 Nov 2001 17:13:13
Message: <3c001b78@news.povray.org>
: Win32 console apps cannot generate splash screens.
  Are you sure?
  I think (I'm not 100% sure) that console apps can open windows in the same
way as any other windows program.
Date: 24 Nov 2001 18:17:58
Message: <Xns9163BA2618E91CoridonHenshaw@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3c001b78@news.povray.org:
> same  way as any other windows program.
Pretty much by definition any app which creates windows ceases to be a
console mode app.
Again, are you asserting that it is illegal to port Povray to a text-based
platform?  (y/n)
Date: 24 Nov 2001 18:35:58
Message: <jfb00u4u5qitght0p4vqmug65bjo00r72b@4ax.com>
On 24 Nov 2001 18:17:58 -0500, che### [at] sympaticoca (Coridon Henshaw)
>platform?  (y/n)
It is not, as long as a) the full copyright message is displayed b) it
is clearly stated that it is an unofficial version and the POV Team is
not responsible for this version and c) you take the burden of
supporting it.
Peter Popov ICQ : 15002700
Date: 24 Nov 2001 18:55:32
Message: <3c003373@news.povray.org>
: Pretty much by definition any app which creates windows ceases to be a
: console mode app.
  Not true.
  For example a program could be used from the console, it could read
commands and execute them, etc, and it could open windows for example for
drawing a graph (matlab works this way in X).
