POV-Ray : Newsgroups : povray.beta-test : Splash Screen Server Time
19 May 2026 00:09:49 EDT (-0400)
  Splash Screen (Message 2 to 11 of 31)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Splash Screen
Date: 19 Nov 2001 17:24:54
Message: <3bf986b6@news.povray.org>
In article <3bf97aba@news.povray.org> , "Tom Galvin"
<tom### [at] nospamdataforgecom> wrote:
> Is there a way to supress the splash screen in the windows 3.5 beta version?
No, it isn't allowed by the license to disable the copyright messages of
POV-Ray.
    Thorsten
Date: 23 Nov 2001 18:07:05
Message: <3bfed699@news.povray.org>
version?
> POV-Ray.
>     Thorsten
I am not looking to disable the copyright, it is also in the messages window
of the IDE.  I just don't want the splash screen popping up every time when
I run pov in the background from an external batch file.  I guess from your
answer, it is not possible with 3.5.  I will wait to see if I can make the
request for 4.0 to have the option.
Thanks for the quick reply
Tom
Date: 24 Nov 2001 00:04:36
Message: <Xns9163C70592ECoridonHenshaw@204.213.191.226>
"Tom Galvin" <tom### [at] nospamdataforgecom> wrote in
news:3bfed699@news.povray.org:
> window of the IDE.  I just don't want the splash screen popping up
> every time when I run pov in the background from an external batch
> file.
Your best bet here is probably to wait until the 3.5 sources release and
then compile a Win32 command-line version using a cut-down DOS front end.
The DOS front end doesn't throw up a splash screen so you can run
background renders--completely within the terms of povlegal--without
getting splashed.
Date: 24 Nov 2001 02:50:26
Message: <slrn9vuka2.bpn.ron.parker@fwi.com>
>> file.
There is no 3.5 DOS front end.  HTH, HAND.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 24 Nov 2001 03:48:17
Message: <3bff5ed1$1@news.povray.org>
Just curious: which platforms won't be supported?
Jonathan.
Date: 24 Nov 2001 04:45:08
Message: <3bff6c24$1@news.povray.org>
Tom Galvin schrieb in Nachricht <3bfed699@news.povray.org>...
window
>Tom
The best solution I found yet was to open Pov before starting the script and
activate "Keep single instance". This way no Splash Screen is shown for each
frame. Pov gets the focus at each frame anyway, though.
Marc-Hendrik
Date: 24 Nov 2001 05:07:03
Message: <3bff7147$1@news.povray.org>
In article <3bff5ed1$1@news.povray.org> , "JRG" <jrg### [at] hotmailcom> wrote:
All platforms can be supported.  The POV-Team will only support a Windows,
Mac OS and Linux x86 version.
    Thorsten
e-mail: tho### [at] trfde
Date: 24 Nov 2001 05:41:06
Message: <3bff7942@news.povray.org>
Coridon Henshaw <che### [at] sympaticoca> wrote:
: Your best bet here is probably to wait until the 3.5 sources release and
: then compile a Win32 command-line version using a cut-down DOS front end.
: The DOS front end doesn't throw up a splash screen so you can run
: background renders--completely within the terms of povlegal--without
: getting splashed.
  Just be sure to not to distribute this version.
Date: 24 Nov 2001 06:04:30
Message: <3BFF7EB9.FBF8782E@gmx.de>
I suppose there is simply not enough demand for a DOS version, if you
really want one, you can always compile the unix version with DJGPP.
Date: 24 Nov 2001 11:16:55
Message: <slrn9vvhvp.do9.ron.parker@fwi.com>
>: getting splashed.
It can be distributed, so long as it meets all the rules set out in POVLegal.
That means it has to display the copyright notice, of course, but it doesn't
have to bring up a splash screen as it would be based on a (nonexistent)
version that doesn't actually bring up a splash screen.
Of course, the Unix version can be redirected to /dev/null and all copyright
text gets sent to the bit bucket; I don't know of any way to prevent that
sort of abuse and still provide a command-line version of POV.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
