POV-Ray : Newsgroups : povray.beta-test : [doc] ... only a small change ... Server Time
14 Jun 2026 10:50:59 EDT (-0400)
  [doc] ... only a small change ... (Message 1 to 2 of 2)
Subject: [doc] ... only a small change ...
Date: 16 Nov 2001 08:48:18
Message: <3bf51922$1@news.povray.org>
OK ... I know ..
It's my fault, if I'm unable to read correctly ... ;)
I know myself, that I'm to dumb, BUT:
I had a macro that I used to create a mesh of triangles ....
When I tried to convert it for smooth_triangles, I needed to look
into the doc (shame on me ...;)
I browsed through and looked for the changes between mesh and smooth-mesh
OK ...
in 6.5.2.3 Mesh
there is written the following ...
MESH_TRIANGLE:
    triangle
        <Corner_1>, <Corner_2>, <Corner_3>
        [uv_vectors <uv_Corner_1>, <uv_Corner_2>, <uv_Corner_3>]
        [MESH_TEXTURE]
    smooth_triangle
        <Corner_1>, <Normal_1>, <Corner_2>,
        <Normal_2>, <Corner_3>, <Normal_3>
        [MESH_TEXTURE]
Can you imagine, that I wrote now
    <Corner1>,<Corner2>,<Corner3>,
    <Normal1>,<Normal2>,<Normal3> ???
Even worse ... I needed, at least 2 hours to figure out, that it was written
in
the doc in a distracting way ...
is it possible, to change the doc a minor bit, that there is:
    smooth_triangle
        <Corner_2>, <Normal_2>,
        [MESH_TEXTURE]
so one still can figure out, what happens, if you only fly through the thing
(Yeah ... you can call me a Warmduscher, that I need the doc for mesh-syntax
Jan Walzer <jan### [at] lzernet>
Subject: Re: [doc] ... only a small change ...
Date: 16 Nov 2001 09:43:38
Message: <Xns915B9FFC69E94seed7@povray.org>
>     smooth_triangle
yes
Ingo
