POV-Ray : Newsgroups : povray.beta-test : 3.5b7 illegal operation at every render Server Time
2 Nov 2024 15:24:43 EDT (-0400)
  3.5b7 illegal operation at every render (Message 1 to 8 of 8)
Subject: 3.5b7 illegal operation at every render
Date: 14 Nov 2001 11:28:53
Message: <memo.20011114162852.48355A@blue.compulink.co.uk>
I've just installed v3.5 beta 7 and am getting an illegal operation every time I try
to render a scene.
System: Abit Be6/500MHz PIII/256MB/Windows 95 OSR2
Example errors:
Rendering Woodbox.pov
PVENGINE executed an invalid instruction in module PVENGINE.EXE at
014f:0056a306.
Registers:
EAX=00000000 CS=014f EIP=0056a306 EFLGS=00010246
EBX=00000000 SS=0157 ESP=020df98c EBP=020df98c
ECX=00000000 DS=0157 ESI=00a5a95c FS=5387
EDX=005db980 ES=0157 EDI=020dfb48 GS=0000
Bytes at CS:EIP:
0f 28 c0 b8 01 00 00 00 8b e5 5d c3 33 c0 8b e5
Stack dump:
020df9c4 0056a3e1 020df9e0 bff7adc9 020dfb00 020dfbb0 004fba44
bff7ae02 0000001c 81986190 81999514 9999999a 0387f9ff 00000673
00a5a7d8 00a5a95c
Rendering Biscuit.pov
014f:0056a306.
Registers:
EBX=00000000 SS=0157 ESP=0231f97c EBP=0231f97c
ECX=00000000 DS=0157 ESI=0231fb68 FS=50b7
EDX=005db980 ES=0157 EDI=0231fb50 GS=0000
Bytes at CS:EIP:
Stack dump:
0231f9b4 0056a3e1 00000008 005b5ea0 00000400 00000001 00000000
00000000 00000000 0231f9d4 00567d31 0231f9c8 0387f9ff 00000673
00a693d8 0231fb68
Re-rendering insert menu bitmaps:
module PVENGINE.EXE at 014f:0056a306.
Registers:
EBX=00000000 SS=0157 ESP=020df32c EBP=020df32c
ECX=00000000 DS=0157 ESI=020df75c FS=4d1f
EDX=005db980 ES=0157 EDI=00a5dbe0 GS=0000
Bytes at CS:EIP:
Stack dump:
020df364 0056a3e1 006222a0 00608d74 020df828 0000003e 004f8a35
005b36b0 005b36b0 00000000 0000000d 020df618 0387f9ff 00000673
00a5dbd4 020df75c
Any ideas?
Jon.
Subject: Re: 3.5b7 illegal operation at every render
Date: 14 Nov 2001 11:35:18
Message: <b775vt4gmd7abcno224dqtovms7co0aan5@4ax.com>
On Wed, 14 Nov 2001 16:28 +0000 (GMT), Jon### [at] bluespamoffcixcouk (Jon O'Brien)
wrote:
> Any ideas?
Have you tested this with another compile version at
http://www.povray.org/binaries/windows/pvengine-vc6-beta-7.zip ?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 14 Nov 2001 13:49:17
Message: <memo.20011114184918.5607A@blue.compulink.co.uk>
In article <b775vt4gmd7abcno224dqtovms7co0aan5@4ax.com>,
I have now and it works perfectly.
Many thanks,
Jon.
Date: 16 Nov 2001 07:32:02
Message: <3bf50742@news.povray.org>
I have also recently downloaded 3.5 beta test and confirm Jon O'Brien's
experience. I have conistently managed one render without Povray crashing:
slopemt_dat.pov seems to run OK. I have uninstalled and reinstalled several
times and the illegal operations described in Mr O'Brien's message occur
every time, with the one exception mentioned above.
I am running on a 1GHz  P4 with 128MB and Windows 95 B,
Is this a general problem or just me and Jon?
Brian Fileman
return e-mail address: bdf### [at] wildblood-macdonaldcom or
bri### [at] filemanfreeservecouk
Jon O'Brien <Jon### [at] bluespamoffcixcouk> wrote in message
news:mem### [at] bluecompulinkcouk...
time I try
> to render a scene.
> Example errors:
> 014f:0056a306.
> Registers:
> Bytes at CS:EIP:
> Stack dump:
> 00a5a7d8 00a5a95c
> 014f:0056a306.
> Registers:
> Bytes at CS:EIP:
> Stack dump:
> 00a693d8 0231fb68
> Registers:
> Bytes at CS:EIP:
> Stack dump:
> 00a5dbd4 020df75c
> Any ideas?
> Jon.
Date: 17 Nov 2001 14:09:21
Message: <3bf6b166.4310568@localhost>
>to render a scene.
	Interesting.  I had a similar error every time I rendered a
scene on the Windows 95 machine at work.  I had posted this a few
weeks back (beta 6) but no one else could get it to happen (some
people were nice enough to try, thanks!).  Until you posted, I
wondered if perhaps it was a problem ONLY on my system.  It seemed to
happen on any scene that used a #while in it.
	Since then, the machine at work was wiped and they put Windows
2000 on it so the problem disapeared so I can not investigate this
further.  :(
	Can you render the biscuit.pov file that comes with povray?
Pete
Date: 18 Nov 2001 21:15:23
Message: <memo.20011119021524.41447A@blue.compulink.co.uk>
In article <3bf6b166.4310568@localhost>, PeterC@nym.alias.net.almost
I couldn't render either of the demo scenes or re-render the insert menu
bitmaps. I only tried one other scene, which renders OK in 3.1, and that failed
too.
Jon.
Date: 23 Nov 2001 10:47:02
Message: <3bfd6f39.17941071@localhost>
On Mon, 19 Nov 2001 02:15 +0000 (GMT), Jon### [at] bluespamoffcixcouk (Jon
>too.
>Jon.
Hmmm.  That is very much my experience with beta six on the
Windows 95 machine.
One more silly thing to try.  Try to render this next scene
in 3.5:
/* simple test */
  location 0
  direction <0, 0, 1>
  right <(640 / 480), 0, 0>
  up <0, 1, 0>
  translate <0, 2, -10>
sphere {
  <0, 0, 0>, 1
  pigment { color rgb <0, 0.5, 1> }
  finish { ambient 0.4 diffuse 0.6 }
plane {
  <0, 1, 0>, 0
  pigment { color rgb 1 }
  finish { ambient 0.3 diffuse 0.7 }
light_source {
  <-3000, 3000, -3000>
  color rgb 1
/* actual end of this file */
Date: 27 Nov 2001 01:52:54
Message: <memo.20011127065254.47027B@blue.compulink.co.uk>
In article <3bfd6f39.17941071@localhost>, PeterC@nym.alias.net.almost
> in 3.5:
Sorry for the delay in responding.
I don't have a copy of the Intel compiled binary anymore, I'm afraid.
Jon.
