I'm working on a scene with a table made of iso-plankes (just like those in
the isowood include file). With the beta 7 these isos render MUCH slower:
beta 6: 1 m 45 s
beta 7: 8 m 22 s.
These planks are simple f_rounded_box displaced with a wood pigment.
Christoph, can you confirm?
POV-Ray 3.5 beta 7 Windows ME Athlon
(Intel compile)
Jonathan.
In article <3bdf24b3$1@news.povray.org> , "JRG" <jrg### [at] hotmailcom> wrote:
> beta 6: 1 m 45 s
> beta 7: 8 m 22 s.
Providing a scene might be useful....
Thorsten
Right:
Here is the code without modifications:
#include "functions.inc"
//#include "woodmaps.inc"
#include "woods.inc"
#declare table_x=150;
#declare table_y=3;
#declare table_z=90;
#declare n=8;
#declare RS=seed(0);
#declare i=0;
#while (i<n)
#declare pig_wood=
wood
scale 0.5
turbulence 0.07
rotate 90*y
warp {
black_hole
<0,3/2,0>, 2
strength 2
falloff 2
inverse
repeat 2*<10,0,10>
turbulence 0.5
rotate <rand(RS),rand(RS),rand(RS)>*2 translate
<rand(RS),rand(RS)*0,rand(RS)>*30
#declare pig_func=
function { pigment {pig_wood color_map {[0 rgb 0][1 rgb 1]}}}
isosurface {
function {
f_rounded_box (x,y,z,0.5,table_x/2,table_y/2,table_z/2/n) +
pig_func(x,y,z).gray*0.08
accuracy 10^-3
max_gradient 2
evaluate 1,10,.99
contained_by {box {-<table_x,table_y,table_z/n>/2,
<table_x,table_y,table_z/n>/2}}
pig_wood
color_map {M_Wood3A}
finish {ambient 0 diffuse 0.8 specular 0.1 roughness 0.02 brilliance
1.25}
scale <1,1,0.99>
translate (-table_z/n/2-table_z/n*i)*z+(-0.25+0.5*rand(RS))*y
translate 50*z
#undef pig_func //without this one it crashes (in beta 6. I don't know about
beta 7 (which I have to reinstall))
#declare i=i+1;
location <0,20,-50>
look_at 0
rotate 10*y}
light_source {
<150,150,-150>
rgb 1.5
fade_power 2
fade_distance 300}
background {rgb 0.5}
Subject: Re: Isosurfaces *much* slower in beta 7?
Date: 30 Oct 2001 18:37:23
Message: <3bdf39b3@news.povray.org>
In article <3bdf2d82@news.povray.org> , "JRG" <jrg### [at] hotmailcom> wrote:
> evaluate
I can confirm that isosurfaces that use "evaluate", and *only* isosurfaces
that use "evaluate" exhibit this speed problem in beta 7. The workaround is
to use "evaluate" only if absolutely necessary.
Thorsten
e-mail: tho### [at] trfde
Thorsten Froehlich <tho### [at] trfde> wrote:
: I can confirm that isosurfaces that use "evaluate", and *only* isosurfaces
: that use "evaluate" exhibit this speed problem in beta 7. The workaround is
: to use "evaluate" only if absolutely necessary.
Is this phenomenon temporary or has it came to stay?
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
Date: 31 Oct 2001 04:02:51
Message: <3bdfbe3b@news.povray.org>
In article <3bdf9c43@news.povray.org> , Warp <war### [at] tagpovrayorg> wrote:
> : The workaround is
Workaround usually suggests something temmporary for me. As far as details
are concerned, after looking a bit closer into the code for "evaluate" it
seems like it is almost redundant: The parameters you specifc after the
"evaluate" keyword only had a function if no max_gradient was set.
Consequently this would lead to the odd behavior that if and only if the
default max_gradient (which is 1.1) was used, max_gradient itself would be
adjusted. Unfortunately, due to a logic mistake I kept one of these
modifications of max_gradient also it should have been removed. I think I
have a fix for this already*.
Thorsten
* Warp: Do a sync (get change 1235) to try it.
Date: 31 Oct 2001 04:08:02
Message: <3BDFBF72.F7D52C4F@gmx.de>
That's really sad, i was just starting to use it intensively. Apart from
being incredibly slow it also seems to produce wrong results.
Christoph Hormann <chr### [at] gmxde>
Date: 31 Oct 2001 04:27:30
Message: <3bdfc402@news.povray.org>
In article <3BDFBF72.F7D52C4F@gmx.de> , Christoph Hormann
That is part of beta testing. It is not really a serious problem, it is
just very slow...
> Apart from
No, it only changes your max_gradient. The reported found maximum gradient
value is still correct.
Thorsten
Date: 31 Oct 2001 04:39:29
Message: <3BDFC6D1.332E1CE6@gmx.de>
> beta 6: 1 m 45 s
> beta 7: 8 m 22 s.
I can confirm that evaluate can be quite slow. NTL, with the isowood
sample i tried, evaluate led to faster results for some reason. Note that
it only worked with the MSVC compile, the intel version still crashes
(probably because of the function declaration problems)
In article <3BDFC6D1.332E1CE6@gmx.de> , Christoph Hormann
No, those should be gone.
Thorsten
