POV-Ray : Newsgroups : povray.beta-test : Bug in image.c? Server Time
11 Apr 2026 14:40:59 EDT (-0400)
  Bug in image.c? (Message 1 to 1 of 1)
Subject: Bug in image.c?
Date: 31 Oct 2001 01:19:18
Message: <3bdf97e6@news.povray.org>
I found a possible bug in image.c of V3.1g.
If this has been already fixed in V3.5, I am sorry for
the posting.
The below C code is 'bilinear' function in image.c of V3.1g.
I think  the "if ((p == 0.0) && (q == 0.0)) {...}" was
added in order to reduce the calculation time.
But the return value with the 'if' statement is different
from the value without the statement in case p=0 and q=0.
The return value in the 'if' statement should be *(corners+3).
Or, it's better to remove the 'if' statement, because
probability of the 'if' case is very small in usual interpolation
processes.
Same as 'norm_dist' function.
R. Suzuki
static DBL bilinear(DBL *corners, DBL  x, DBL  y)
  DBL p, q;
  DBL val;
  p = x - (int)x;
  q = y - (int)y;
    return (*corners);  /* upper left */
  val = (p * q * *corners) + (q * (1 - p) * *(corners + 1)) +
    (p * (1 - q) * *(corners + 2)) + ((1 - p) * (1 - q) * *(corners + 3));
  return (val);
