POV-Ray : Newsgroups : povray.beta-test : Isosurfaces *much* slower in beta 7? Server Time
17 May 2026 11:12:47 EDT (-0400)
  Isosurfaces *much* slower in beta 7? (Message 1 to 10 of 29)
Subject: Isosurfaces *much* slower in beta 7?
Date: 30 Oct 2001 17:07:47
Message: <3bdf24b3$1@news.povray.org>
I'm working on a scene with a table made of iso-plankes (just like those in
the isowood include file). With the beta 7 these isos render MUCH slower:
beta 6: 1 m 45 s
beta 7: 8 m 22 s.
These planks are simple f_rounded_box displaced with a wood pigment.
Christoph, can you confirm?
POV-Ray 3.5 beta 7 Windows ME Athlon
(Intel compile)
Jonathan.
Subject: Re: Isosurfaces *much* slower in beta 7?
Date: 30 Oct 2001 17:36:56
Message: <3bdf2b88$1@news.povray.org>
In article <3bdf24b3$1@news.povray.org> , "JRG" <jrg### [at] hotmailcom> wrote:
> beta 6: 1 m 45 s
> beta 7: 8 m 22 s.
Providing a scene might be useful....
    Thorsten
Date: 30 Oct 2001 17:45:22
Message: <3bdf2d82@news.povray.org>
Right:
Here is the code without modifications:
#include "functions.inc"
//#include "woodmaps.inc"
#include "woods.inc"
#declare table_x=150;
#declare table_y=3;
#declare table_z=90;
#declare n=8;
#declare RS=seed(0);
#declare i=0;
#while (i<n)
#declare pig_wood=
    wood
    scale 0.5
    turbulence 0.07
    rotate 90*y
    warp {
        black_hole
        <0,3/2,0>, 2
        strength 2
        falloff 2
        inverse
        repeat 2*<10,0,10>
        turbulence 0.5
     rotate <rand(RS),rand(RS),rand(RS)>*2 translate
<rand(RS),rand(RS)*0,rand(RS)>*30
#declare pig_func=
function { pigment {pig_wood color_map {[0 rgb 0][1 rgb 1]}}}
isosurface {
    function {
        f_rounded_box (x,y,z,0.5,table_x/2,table_y/2,table_z/2/n) +
pig_func(x,y,z).gray*0.08
    accuracy 10^-3
    max_gradient 2
    evaluate 1,10,.99
    contained_by {box {-<table_x,table_y,table_z/n>/2,
<table_x,table_y,table_z/n>/2}}
        pig_wood
        color_map {M_Wood3A}
    finish {ambient 0 diffuse 0.8 specular 0.1 roughness 0.02 brilliance
1.25}
    scale <1,1,0.99>
    translate (-table_z/n/2-table_z/n*i)*z+(-0.25+0.5*rand(RS))*y
    translate 50*z
#undef pig_func //without this one it crashes (in beta 6. I don't know about
beta 7 (which I have to reinstall))
#declare i=i+1;
    location <0,20,-50>
    look_at 0
    rotate 10*y}
light_source {
    <150,150,-150>
    rgb 1.5
    fade_power 2
    fade_distance 300}
background {rgb 0.5}
Date: 30 Oct 2001 18:37:23
Message: <3bdf39b3@news.povray.org>
In article <3bdf2d82@news.povray.org> , "JRG" <jrg### [at] hotmailcom> wrote:
>  evaluate
I can confirm that isosurfaces that use "evaluate", and *only* isosurfaces
that use "evaluate" exhibit this speed problem in beta 7.  The workaround is
to use "evaluate" only if absolutely necessary.
    Thorsten
e-mail: tho### [at] trfde
Date: 31 Oct 2001 01:37:55
Message: <3bdf9c43@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: I can confirm that isosurfaces that use "evaluate", and *only* isosurfaces
: that use "evaluate" exhibit this speed problem in beta 7.  The workaround is
: to use "evaluate" only if absolutely necessary.
  Is this phenomenon temporary or has it came to stay?
Date: 31 Oct 2001 04:02:51
Message: <3bdfbe3b@news.povray.org>
In article <3bdf9c43@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> : The workaround is
Workaround usually suggests something temmporary for me.  As far as details
are concerned, after looking a bit closer into the code for "evaluate" it
seems like it is almost redundant:  The parameters you specifc after the
"evaluate" keyword only had a function if no max_gradient was set.
Consequently this would lead to the odd behavior that if and only if the
default max_gradient (which is 1.1) was used, max_gradient itself would be
adjusted.  Unfortunately, due to a logic mistake I kept one of these
modifications of max_gradient also it should have been removed.  I think I
have a fix for this already*.
    Thorsten
* Warp: Do a sync (get change 1235) to try it.
Date: 31 Oct 2001 04:08:02
Message: <3BDFBF72.F7D52C4F@gmx.de>
That's really sad, i was just starting to use it intensively.  Apart from
being incredibly slow it also seems to produce wrong results.
Date: 31 Oct 2001 04:27:30
Message: <3bdfc402@news.povray.org>
In article <3BDFBF72.F7D52C4F@gmx.de> , Christoph Hormann
That is part of beta testing.  It is not really a serious problem, it is
just very slow...
> Apart from
No, it only changes your max_gradient.  The reported found maximum gradient
value is still correct.
    Thorsten
Date: 31 Oct 2001 04:39:29
Message: <3BDFC6D1.332E1CE6@gmx.de>
> beta 6: 1 m 45 s
> beta 7: 8 m 22 s.
I can confirm that evaluate can be quite slow.  NTL, with the isowood
sample i tried, evaluate led to faster results for some reason.  Note that
it only worked with the MSVC compile, the intel version still crashes
(probably because of the function declaration problems)
Date: 31 Oct 2001 04:46:02
Message: <3bdfc85a$1@news.povray.org>
In article <3BDFC6D1.332E1CE6@gmx.de> , Christoph Hormann
No, those should be gone.
    Thorsten
