POV-Ray : Newsgroups : povray.beta-test : Function parameter bug Server Time
18 Feb 2026 20:34:42 EST (-0500)
  Function parameter bug (Message 1 to 10 of 25)
Subject: Function parameter bug
Date: 26 Oct 2001 17:17:45
Message: <3bd9d2f9@news.povray.org>
I'm not that much into how functions work and should work, but this surely
must be a bug?
The following code:
#declare V = 0.1;
#declare Myfunction = function (V) {V*2}
sphere {x, V}
Gives the error:
"#declare V = 0.1;
#declare Myfunction = function (V <----ERROR
Parse Error: Expected 'parameter identifier', float function 'float
identifier' found instead
Returned from renderer with error status"
I'm using POV-Ray 3.5 beta 6
on a P150, 16MB RAM
Windows 95  4.00.450 B  IE 5 5.00.2919.6307
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Subject: Re: Function parameter bug
Date: 26 Oct 2001 19:40:30
Message: <3bd9f46e@news.povray.org>
V does not represent your function, it's just a parameter. As it is now you
are telling povray to do:
#declare Myfunction (0.1) (0.1*2)
sphere {x, 0.1)
which isn't correct.
try something like this:
sphere {x, Myfunction (0.1)}
Jonathan.
Date: 26 Oct 2001 20:18:22
Message: <3bd9fd4e@news.povray.org>
> parameter. As it is now you are telling povray to do:
But shouldn't the parameters use a different name-space than things declared
outside of the functions, just like it works with macros?
This:
#declare V = 0.1;
#include "math.inc"
gives an error because a function in math.inc uses V as a parameter! We
can't have that, now can we?
No because that's not what I want. I want the function to leave alone my
declared floats and stop bothering them.
Rune
Date: 27 Oct 2001 02:54:33
Message: <3BDA5A29.18F49D99@gmx.de>
Since it's leagal to use declared variables in functions, this would lead
to at least a lot of confusion.
Date: 27 Oct 2001 04:48:55
Message: <3bda74f7@news.povray.org>
Ah aaah.... now I understand...
You want to give your float identifiers any name you want without bothering
that that name is already used somewhere (for example in math.inc) as a
function parameter. But why bother? Just use another identifier. Of course I
usually expect an uppercased identifier (such as R) to work in any
situation, but this could be just a minor problem in math.inc design.
Jonathan.
"Rune" <run### [at] mobilixnetdk> ha scritto nel messaggio
news:3bd9fd4e@news.povray.org...
declared
> This:
> #declare V = 0.1;
> #include "math.inc"
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 27 Oct 2001 05:48:55
Message: <3bda8307@news.povray.org>
In article <3bd9fd4e@news.povray.org> , "Rune" <run### [at] mobilixnetdk>
No, because one is the scene level and the other the parser level.  The
parser values are inserted first by substituting every variable you
declared.  The resulting scene file (which is invisible to you) is the
passed on the the actual parser which only sees the 0.1 as it should because
the "V" has been substituted by "0.1" as you requested.
You mistake is part of the functions are no macros misunderstanding!
    Thorsten
e-mail: tho### [at] trfde
Date: 27 Oct 2001 05:51:37
Message: <3bda83a9$1@news.povray.org>
When you *call* functions, not when you initiate them! At least it shouldn't
be since it makes no sense at all.
Take a macro:
#declare V = 0.1:
#macro MyMacro(V) V*2 #end
sphere {x, 0.1}
Here's there's no problem since the parameter in the macro doesn't conflict
with already declared variables. You can still call the macro with the
declared variable and *then* it will be used:
#declare B = MyMacro(V);
But with functions a conflict happens at the time of declaring the function
and that's all wrong.
Rune
Date: 27 Oct 2001 05:51:39
Message: <3bda83ab$1@news.povray.org>
To use long cryptic parameter names and/or variable names just to avoid a
name conflicts is not an acceptable solution. You can never know if some
include file uses the same name you're using for your variables.
Rune
Date: 27 Oct 2001 06:06:07
Message: <3bda870f@news.povray.org>
In article <3bda83a9$1@news.povray.org> , "Rune"
> Take a macro:
> #declare V = 0.1:
> sphere {x, 0.1}
Repeat after we:
Functions are not macros.  Functions are not macros.  Functions are not
macros.  Functions are not macros.   Functions are not macros. ...
    Thorsten
Date: 27 Oct 2001 06:09:18
Message: <3bda87ce@news.povray.org>
"Thorsten Froehlich" wrote:
> The parser values are inserted first by substituting
> every variable you declared.
But it doesn't make sense to have parameters that are constant! And indeed
an error is generated as I reported! The *only* result of the way it woks
now is apparently that parameter names cannot use the same name as declared
variables and that's *very* inconvenient, as it's very common to use
one-letter names for both variables and for function parameters.
But what's the logic behind how it works? It seems to be a big limitation
that have no positive effects at all...
Rune
