POV-Ray : Newsgroups : povray.beta-test : Commented out Server Time
31 Mar 2026 17:12:49 EDT (-0400)
  Commented out (Message 1 to 3 of 3)
Subject: Commented out
Date: 24 Oct 2001 19:14:30
Message: <3bd74b56@news.povray.org>
-Hail
   Take any part of code comment it out using /*  ....   */ make sure the
last */ is on its own line and then select that line by clicking on the left
margin. Delete it and you will notice the rest of the code is commented out.
This is all good so far but if you undo then the */ returns but the code is
still yellow although it renders correctly.
Subject: Re: Commented out
Date: 25 Oct 2001 00:28:01
Message: <3bd794d1@news.povray.org>
left
out.
is
Yep. This does happen.
N Shomber
Date: 25 Oct 2001 11:33:22
Message: <3bd830c2@news.povray.org>
Vampyrium <cyb### [at] hotmailcom> wrote:
:    Take any part of code comment it out using /*  ....   */ make sure the
: last */ is on its own line and then select that line by clicking on the left
: margin. Delete it and you will notice the rest of the code is commented out.
: This is all good so far but if you undo then the */ returns but the code is
: still yellow although it renders correctly.
  I would bet it's a problem with the codemax editor and not easy to fix...
(I could be wrong, of course).
