POV-Ray : Newsgroups : povray.beta-test : mesh bug Server Time
11 Apr 2026 16:29:28 EDT (-0400)
  mesh bug (Message 1 to 5 of 5)
Subject: mesh bug
Date: 23 Oct 2001 11:52:02
Message: <3bd59222@news.povray.org>
Windows 95 pov 3.5b6
The following code (which is pretty much the mesh object from the insert
menu) renders fine the first time, but on subsequent renders, there appear
to be co-incident surfaces or similiar. I have to close pov and restart to
get a correct render, but the problem returns on subsequent re-renders.
I've posted first render and second render images to beta binaries just in
case this problem doesn't reproduce on other systems...
#version 3.5;
global_settings {
  assumed_gamma 1.0
  location  <0.0, 0.5, -10.0>
  look_at   <0.0, 0.0,  0.0>
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
//plane {  y, -1  pigment { color rgb <0.7,0.5,0.3> }}
#declare T1=texture {pigment{Red}}
#declare T2=texture {pigment{Green}}
#declare T3=texture {pigment{Blue}}
mesh { // box example here
  /* top side */
  triangle { <-2,  2, -2>, < 2,  2, -2>, < 2,  2,  2> }
  triangle { <-2,  2, -2>, <-2,  2,  2>, < 2,  2,  2> texture { T1 } }
  /* bottom side */
  triangle { <-2, -2, -2>, < 2, -2, -2>, < 2, -2,  2> }
  triangle { <-2, -2, -2>, <-2, -2,  2>, < 2, -2,  2> }
  /* left side */
  triangle { <-2, -2, -2>, <-2, -2,  2>, <-2,  2,  2> }
  triangle { <-2, -2, -2>, <-2,  2, -2>, <-2,  2,  2> }
  /* right side */
  triangle { < 2, -2, -2>, < 2, -2,  2>, < 2,  2,  2> texture { T2 } }
  triangle { < 2, -2, -2>, < 2,  2, -2>, < 2,  2,  2> texture { T2 } }
  /* front side */
  triangle { <-2, -2, -2>, < 2, -2, -2>, <-2,  2, -2> texture { T3 } }
  triangle { <-2,  2, -2>, < 2,  2, -2>, < 2, -2, -2> texture { T3 } }
  /* back side */
  triangle { <-2, -2,  2>, < 2, -2,  2>, <-2,  2,  2> }
  triangle { <-2,  2,  2>, < 2,  2,  2>, < 2, -2,  2> }
  texture
  { // remaining triangles get this texture
    pigment {Yellow}
    finish { ambient 0.2 diffuse 0.7 }
  rotate y*45
Subject: Re: mesh bug
Date: 23 Oct 2001 13:29:59
Message: <3BD5A81C.DD974988@ewetel.net>
Hello Tom :-))
Tom Melly:
I can confirm this: First and second runs are ok. The problem appears in the
third run.
Everything is ok after restarting POV... But only for two runs.
Thorsten
(3.5b6, P2, w95)
Date: 23 Oct 2001 14:44:00
Message: <3bd5ba70@news.povray.org>
Thorsten wrote in message <3BD5A81C.DD974988@ewetel.net>...
the
>third run.
Weird - I thought it must be something stupid with my machine - can't wait
to hear the explanation for this one. btw it doesn't show up on all meshes
as far as I can tell. I made a simple mesh (3 sided pyramid with a base) and
couldn't reproduce it, but I don't know if that was the simplicity or
different arrangement of textures...
Date: 23 Oct 2001 15:33:28
Message: <3bd5c608@news.povray.org>
Tom Melly wrote in message <3bd59222@news.povray.org>...
<snip>
Just to add something to this - switching to another app and then back again
clears the problem for one render (it doesn't seem to matter whether you do
anything in the other app or not - switching to a windows explorer window
and back again will do it).
Date: 30 Oct 2001 06:26:34
Message: <3BDE8D51.69C4FE90@ewetel.net>
Hello Tom :-))
Tom Melly:
This problem seems to be partially solved...
It does not happen with 3.5.beta.7.icl.win32 :-))
But it is still present with 3.5.beta.7.msvc.win32.
Maybe this could give someone a hint to solve the problem.
Greetings :-))
Thorsten
