POV-Ray : Newsgroups : povray.beta-test : #error bug Server Time
19 May 2026 00:25:16 EDT (-0400)
  #error bug (Message 11 to 20 of 43)
Subject: Re: #error bug
Date: 20 Oct 2001 20:57:55
Message: <3bd21d93@news.povray.org>
"Thorsten Froehlich" wrote:
> "Rune" wrote:
> > So that must be a bug?
> No, because the documentation never says that the
> #error string is printed to the #error stream
Yes it does.
"There are seven distinct text streams that POV-Ray uses for output. You may
output only to three of them."
Look, no matter how you put it there is a bug*, and not just in the
documentation.
If the error directive is supposed to only accept quoted text, but not
pre-defined strings, then there's a bug because it does accept pre-defined
strings.
If the error directive is supposed to accept any string, including
pre-defined strings, then there's a bug because the string is not used for
anything at all, and thus the user don't see the string.
> Oh, and note that the error message is actually displayed
> once already in the line showing with the #error directive...
Not if the error message is a pre-defined string.
* Of course I don't have the final saying in this, but I haven't yet seen
any arguments that indicate otherwise.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 21 Oct 2001 04:22:56
Message: <3bd285e0@news.povray.org>
In article <3bd21d93@news.povray.org> , "Rune" <run### [at] mobilixnetdk>
> Yes it does.
You generate output to the error stream in form of the line quoted by the
"<-- Error" message which dumps the line with the error message.  And note
that the documentation says nothing about actually outputting the string
behind the error message.  In fact after reading it several times I get the
impression the documentation is doing more than just explain the use of text
streams.  It also tells you what those text streams are and that you get a
parse error when using the #error directive.  It never says there can't be a
render time output with these directives, which of course is nonsense.
> strings.
No, because the documentation and the behavior of POV-Ray match in all clear
areas of the documentation.  As the documentation is not clear what happens
with the output, it is up to the user interpretation.
I do agree with you that the situation needs to be improved.
    Thorsten
e-mail: tho### [at] trfde
Date: 21 Oct 2001 04:34:01
Message: <3bd28879@news.povray.org>
About this discussion about the #error directive:
  Also I think that POV-Ray should print the string given to #error.
  Suppose that you have a macro like this, which takes a parameter which
should be a float value which is >=0 and <1:
#macro FancyMacro(Value)
  #if(Value<0 | Value>=1)
    #error concat("In FancyMacro(): Given parameter value ",
                  str(Value,0,-1),
                  " is out of range.\n")
  // Do something fancy here
  And now suppose that you make a slight mistake when calling it:
#declare Ind = 0;
#while(Ind <= 10)
  FancyMacro(Ind/10)
  #declare Ind = Ind+1;
  Now, which error message is clearer, the one POV-Ray currently gives:
File: C:\somepath\somefile.pov  Line: 5
                  str(Value,0,-1),
                  " is out of range.\n") <----ERROR
Parse Error: User error directive hit.
or what POV-Ray *should* print:
In FancyMacro(): Given parameter value 1 is out of range.
  And this does not look like an error message given by POV-Ray itself.
Date: 21 Oct 2001 05:32:20
Message: <3bd29624@news.povray.org>
In article <3bd28879@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
To whom?  The 1% of very advanced users who know each and every error
message POV-Ray can generate?
    Thorsten
Date: 21 Oct 2001 05:50:36
Message: <3BD29A65.B4B44C@free.fr>
Some OS, like VMS, prepend a string to the error that indicates
the application that emits the error, its severity, and a short
error code so that users can look into the index of the manuals.
The remainder of the line is occupied by the actual error message.
POV-Ray could also do that on a very much limited scope. You
could add [POV error] and [POV warning] at the beginning of errors
generated by POV-Ray and [Scripted error] and [Scripted warning]
at the beginning of lines generated by directives. Granted, this
is a bit too verbose, but you get the idea.
You'd still have people who would come complain wrongly, but hey,
they don't even read any error messages, so you could as well
output random error messages for them.
Adrien Beau   adr### [at] freefr   http://adrien.beau.free.fr/
Date: 21 Oct 2001 05:52:43
Message: <3bd29aeb@news.povray.org>
> And note that the documentation says nothing about actually
> outputting the string behind the error message.
That's complete nonsense. From the documentation:
One of those is the #error stream. So the documentation does say that
POV-Ray outputs the string after the #error directive.
Here's some more from the documentation:
"The syntax for a text message is any of the following:
TEXT_STREAM_DIRECTIVE:
    #debug STRING | #error STRING | #warning STRING
Where STRING is any valid string of text including string identifiers or
functions which return strings."
So once and for all, it's clear that the #error stream is supposed to take
any string, including string identifiers or functions which return strings.
But it doesn't. That's a bug!
> line quoted by the "<-- Error" message which dumps the
Right now that's the behavior, but that's clearly not the way it's supposed
to behave. It doesn't take string identifiers or functions which return
strings. It's a bug I tell you! What does it take to convince you???
Rune
Date: 21 Oct 2001 05:52:46
Message: <3bd29aee@news.povray.org>
<snipped example>
I completely agree! But what can mere POV-Ray users do to convince a
POV-Team member?
Rune
Date: 21 Oct 2001 06:00:36
Message: <3bd29cc4@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: To whom?  The 1% of very advanced users who know each and every error
: message POV-Ray can generate?
  Don't tell me that the current behaviour is better. With the current
behaviour you *can't* give reasonable error messages: you can't include
numerical values in the error message, you can't split the error message
into several lines, you can't generate the error message for example by
concatenating strings... Instead of seeing an error message, the user sees
a bunch of POV-Ray SDL code. What good does that do? It also makes the life
of the author of the code harder: If the same error message may happen in
more than one place, he can't use just a string identifier to avoid uselessly
repeating the same string several times.
  In fact, the current behaviour can be even more confusing: As seen in the
example, the user doesn't even see the "#error" keyword if the original code
is split into several lines. Thus the user may not know that it was an #error
command which caused the problem but could think that it is something else.
  If it's such a big deal that the user MUST NOT in any circumstance think
that the error message was generated by POV-Ray itself, then make it clear
by adding something to the messages around the error message string itself,
but allow the maker of the include file to be able to print proper error
messages and not just POV-Ray SDL code to the user. The SDL code doesn't
help the user.
Date: 21 Oct 2001 06:11:42
Message: <3bd29f5e@news.povray.org>
> each and every error message POV-Ray can generate?
If the user isn't familiar with the error, he can search in the manual for
"user error directive" and find out about it there. That's what the
documentation is for. It could also be listed in the VFAQ.
Granted, right now such a search doesn't give clear results, but that could
easily be fixed in the manual.
Rune
Date: 21 Oct 2001 07:38:22
Message: <3bd2b3ae$1@news.povray.org>
In article <3bd29aeb@news.povray.org> , "Rune" <run### [at] mobilixnetdk>
No, it takes the string. It just doesn't output the contents of the string.
    Thorsten
