POV-Ray : Newsgroups : povray.beta-test : Render time counter Server Time
13 Oct 2025 16:19:21 EDT (-0400)
  Render time counter (Message 1 to 9 of 9)
Subject: Render time counter
Date: 17 Oct 2001 08:41:20
Message: <3bcd7c70@news.povray.org>
The render time counter continues to caount when the render is paused.
On my athlon 1GHz it counts at a rate of about 1 second added to the
render time for every 25 seconds real time. On my Pentium 300 it
adds about 1 second to the render time about every 10 minutes real time.
Also is there any reason the tab size cannot be set to 1 character?
Pov-Ray 3.5 beta 6 Win 95 Athlon 1GHz 256MB
Pov-Ray 3.5 beta 6 Win 2000 Pro Pentium 2 300MHz 128 MB
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.          Babylon 5 *
* Just think of me as the storm before the calm     Magic: The Gathering*
Subject: Re: Render time counter
Date: 17 Oct 2001 11:28:30
Message: <3bcda39e@news.povray.org>
"Gail Shaw" <gsh### [at] monotixcoza> wrote in message news:3bcd7c70@news.povray.org...
I don't see this at all (Athlon 1.4ghz) but it is possible under some circumstances.
In any case the render time calculation method is about to be changed, so this will
go away.
It just doesn't. I guess the author of the CodeMax control thought (and I don't
disagree) that if you want a 1-character tab, you ought to be using a space
(since a tab of one character isn't a tab at all, at least in terms of its
original meaning back in the typewriter days).
-- Chris
Date: 17 Oct 2001 12:43:12
Message: <3bcdb520@news.povray.org>
character?
(and I don't
a space
of its
But if you're used to intend with just one space, than decide to add
an union {} - statement you whould have to intend everything in that
union one space. Marking the lines between 'union {' and '}' and
pushing tab would do the trick - if tab equals to one space. If you
mark the lines and push space, the marked block is replaced by a
space - as it should be.
But as it's in a behaviour of the CodeMax control, there's no way
around. Just wanted to show the other side, the one that disagree with
CodeMax control. no harm intended.
Thanks for Povray 3.5 (beta)
cukk
Date: 18 Oct 2001 01:53:52
Message: <3bce6e70@news.povray.org>
"Chris Cason" <newsadmin-despam-@povray-no-spam.org> wrote in message
news:3bcda39e@news.povray.org...
circumstances.
this will
> go away.
Ok, not serious anyway, just a little strange
don't
space
Having never used a typewriter, I have no idea of the original meaning
<grin>
The reason I asked is that I always indent 1 character. If the tab could be
set
to 1 then I could select all the lines and pres tab instead of <Space><Home>
<Down Arrow>  for each line.
Thanks for the answer. If it can't be fixed, it can't be fixed.
Gail
Date: 18 Oct 2001 13:56:52
Message: <3bcf17e4@news.povray.org>
> <grin>
Well, for history's sake ... old mechanical typwriters had a bar at the back
of the carriage, filled with little metal tabs. You could slide one of these
tabs out for each 'tab stop'. The mechanism operated by the tab key would
catch on any metal tab that was extended. When you pressed the tab key, it
would release its hold on the current metal tab and the entire carriage would
then slide along (under spring power) until it hit the next extended tab ...
I'm not sure if the tab key is named after those metal tabs or the concept
of a 'table' (which is what they were usually used for). I think it's the
latter.
You could record a macro and assign it to a key. At least then it's only one
keystroke per line. And don't forget that you can set a 'repeat count' for
the next key you press (Ctrl-R or see the Text menu).
Maybe I'll have a look at the editor source to see if it's easy to change.
-- Chris
Date: 19 Oct 2001 01:57:21
Message: <3bcfc0c1@news.povray.org>
news:3bcf17e4@news.povray.org...
one
Thanks, didn't know about the repeat count. that'll definatly make my life
easier
Gail
Date: 20 Oct 2001 15:04:21
Message: <3bd1cab5$1@news.povray.org>
>[snip]
> -- Chris
BTW how do you undefine/delete/edit a macro? I wondered this with 3.1 but never
thought to ask
Batronyx ^"^
Date: 20 Oct 2001 19:37:25
Message: <3bd20ab5@news.povray.org>
"Batronyx" <bat### [at] alliancecablenet> wrote in message
news:3bd1cab5$1@news.povray.org...
> >[snip]
one
for
change.
never
> thought to ask
After a Ctrl Shift R shows the Stop button you press it after doing what you
want as a macro and choose the slot for it.  Not elegant enough an answer?
:-)  Sorry, being slightly sarcastic and didn't seem to go right.  Well I
guess once they are present you must overwrite from the start again.
Either that or edit the Windows registry to do it, but of course never edit
the things with any ease from Regedit anyway.  That does sound like a nice
feature idea to me but a Codemax one at that.
BTW: HKEY_CURRENT_USER\Software\POV-Ray\v3.5\POV-Edit\Macro
It *could* be done  ;-)
Bob H.
Date: 21 Oct 2001 02:23:13
Message: <3bd269d1$1@news.povray.org>
"Bob H." <omn### [at] msncom> wrote in message news:3bd20ab5@news.povray.org...
I knew I was going to regret asking. :)
>Well I
> Bob H.
Well then, I guess that's the way I'll do it when I need to. I thought maybe I
was overlooking something in the editor.
Batronyx ^"^
