POV-Ray : Newsgroups : povray.beta-test : Will not render Server Time
18 Feb 2026 22:31:06 EST (-0500)
  Will not render (Message 1 to 7 of 7)
Subject: Will not render
Date: 17 Oct 2001 01:04:19
Message: <3bcd1153$1@news.povray.org>
I have been threw all the options, but Moray 3.3 will not send valid files
to Povray, the Povray will work fine if I load a file that was already
started but not a modified file from Moray.  Any idea what I should do?
It should be known that I am not familiar with Moray or Povray, but I learn
quickly.  I just need to get the program runing.  Thanks.
Contact me at s_w### [at] hotmailcom
Copy of Status Window Follows
Command Line Error: Unrecognized output file format X.
Returned from renderer with error status
Preset INI file is 'C:\PROGRAM FILES\POV-RAY FOR WINDOWS
V3.5\renderer\quickres.ini', section is '[512x384, No AA]'.
Preset source file is 'C:\Program Files\POV-Ray for Windows
v3.5\Tutor02d.INI'.
Persistence of Vision(tm) Ray Tracer Version 3.5.beta.6 win32 (.icl)
  This is a time-limited beta test version.  No re-distribution
   of any sort is permitted.
Subject: Re: Will not render
Date: 17 Oct 2001 02:04:45
Message: <3bcd1f7d$1@news.povray.org>
Steve Wilson wrote in message <3bcd1153$1@news.povray.org>...
The files sent by Moray are perfectly valid.
This is (I think) a known problem with Moray.  POV-Ray's interpretation of
some of the command-line parameters changed slightly in POV-Ray 3.5, and
Moray now sends an invalid command line.  The workaround (for now) is to use
Moray with POV-Ray 3.1g.
Mark
Date: 17 Oct 2001 03:35:35
Message: <g7dqst49f5d92n57gg3eeq44laf0u0dl7d@4ax.com>
Hi Steve Wilson, you recently wrote in povray.beta-test:
Edit MORAY.INI and look for a line like this:
HISTOGRAM_TYPE=X
and change the X to NONE.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 17 Oct 2001 10:14:05
Message: <3bcd922d$1@news.povray.org>
Hello Steve again,
Ok, I modified the line HISTOGRAM_TYPE=X to HISTOGRAM_TYPE=NONE. This
allowed Povray to attempt to render the object, but now povray will not
fully render the objects, and will only show the background if it is a
reflection, anyone have any ideas how to get this working?  I would enjoy to
have the ini files from someone already using Moray 3.3 and Povray beta that
is currently working, I have plugging, but have not added them due to the
fact I cannot get the program working without.  I good at using computers,
so you problem will not be talking over my head.  I have taken 2 years of
C++ programming, collage level, and I am also a computer repair man.  It is
just the documentation with the software, and on the site do not seem to
cover these types of problems.  I am almost sure it has something to do with
my Moray configuration.  Thanks again... What follows is the output that
povray gives when I try to render now.
Thanks.
DISCLAIMER : The POV-Team takes no responsibility for the operation of
third-party GUI Extensions.
             DO NOT send us bug reports if they cause things to go haywire.
GUI Extension 'Moray Communications DLL' loaded from 'MorayCtrl.DLL'
  Report any problems to Lutz Kretzschmar <lut### [at] stmuccom>
Persistence of Vision Ray Tracer(tm) for Windows.
POV-Ray for Windows is part of the POV-Ray(tm) suite of programs.
  This is version 3.5.beta.6.icl.win32.
The POV-Ray software is Copyright 1991-2001 POV-Team(tm).
This Windows version is Copyright 1996-2001 Christopher J. Cason.
  It is distributable only under the conditions in POVLEGAL.DOC.
  Select Help|About (or press Alt+B) for more information and a copy of
POVLEGAL.DOC.
The terms POV-Ray, POV-Team, and Persistence of Vision Raytracer are
trademarks of the
  Persistence of Vision Development Team (POV-Team)
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins.
Primary POV-Ray 3.5 Developers: (Alphabetically)
 Chris Cason         Thorsten Froehlich  Nathan Kopp         Ron Parker
Primary POV-Ray 3.0 & 3.1 Developers: (Alphabetically)
 Steve Anger         Dieter Bayer        Chris Dailey        Andreas Dilger
 Steve Demlow        Alexander Enzmann   Dan Farmer          Eduard Schwan
 Timothy Wegner      Chris Young
Major Contributing Authors: (Alphabetically)
 Steve A. Bennett    David K. Buck       Aaron A. Collins    Mark Gordon
 Pascal Massimino    Jim McElhiney       Douglas Muir        Bill Pulver
 Robert Skinner      Zsolt Szalavari     Scott Taylor        Drew Wells
"Lutz Kretzschmar" <lut### [at] stmuccom> wrote in message
news:g7dqst49f5d92n57gg3eeq44laf0u0dl7d@4ax.com...
> HISTOGRAM_TYPE=X
> - Lutz
Date: 17 Oct 2001 19:27:25
Message: <kt4sstshmdmarbe575g8uhcqullhp7d97e@4ax.com>
> ... now povray will not fully render the objects,
What do you mean by this?
> .. and will only show the background if it is a reflection, anyone
This could be due to the alpha channel being active (I think). Maybe
someone else can jump in here.... Warp?
> ... using Moray 3.3 and Povray beta
Note that this combination is currently not working correctly because
Moray is unable to switch off radiosity in POV-Ray. I am working on a
Moray V3.1 patch to alleviate this. Coming Real Soon Now.
- Lutz
Date: 17 Oct 2001 20:49:35
Message: <3bce271f@news.povray.org>
news:kt4sstshmdmarbe575g8uhcqullhp7d97e@4ax.com...
Sounds plausible.  If hf_gray_16 is in the global_settings and alpha output
is also on while a sky_sphere is used too then the objects in the scene will
be semitransparent.  But that's three things used together which isn't
normally done outside of Moray anyway, maybe Steve has put a lot of stuff
together and should attempt to whittle it down to a very basic, simple scene
to troubleshoot from.  *If* that is the case.
Bob H.
> Regards,
> - Lutz
Date: 17 Oct 2001 20:54:18
Message: <3bce283a@news.povray.org>
"Steve Wilson" <s_w### [at] hotmailcom> wrote in message
news:3bcd922d$1@news.povray.org...
haywire.
BTW, that's typical and nothing is wrong, just a message to let you know the
extension is in use.  A error or some problem with the parsing or rendering
in POV-Ray will, for example, show up as a 'Warning:' followed by the
related portion of scene file or similar message.
Bob H.
